With a tripod, that camera should take some excellent images. Like was mentioned earlier - you will want a wide angle lens if you can get it - the 18mm wide that you can get with standard lenses will work for some rooms, but there will be others that will have you doing everything you can to fit a little bit more into the image.
Still, use a tripod, long exposure, and a remote trigger and you should produce beautiful pictures of some beautiful murals.
On a different subject, I found a site that claims that the key wavelengths for the UV reactive paints is in the 365-368 nm range. With most UV LEDs coming in at 385nm+ it was deemed the reason for poor performance compared to flourescents. I know 365nm is available for LEDs - that seems to be the frequency used by the ID checking flashlights.
Of course, it has my curiosity piqued. Is there anybody who has access to both who could check that claim out? I like the idea of the mural lit with LEDs, although it will be some time before I am ready to put one in.
