Originally Posted by NightSkyMurals
Sure... all of the different stencils are just large pieces of paper with holes drilled in them. Some of the stencil kits have 2' x 2' sheets and the Night Sky stencil kit (that I gave the link to) has 2' x 10' and 2' x 12' sheets (depending on the size you get.
You put the paper up on the ceiling and just paint through the holes that are drilled. Then, you take down the paper and you are ready. I believe that most of the stencil kits have about the same number of holes drilled in them... which comes out to about 300-350 for a 10 x 10 room.
Where you see a large hole, you make a larger star by painting a larger circle... and through the smaller holes you paint smaller stars by just touching the tip of the brush to the ceiling.
It is really pretty simple, but time consuming. And, you get a very basic, but nice, little star ceiling.
If you get the stencil (for about $30) and then get paint on the Internet or from me (say, another $30) you can have a decent ceiling for around $70, after you include the shipping.
Hope this helps!
Hope this helps!
Thanks! So it is really that simple.(sort of) I figured it was probably something similar to that, but they didnt have any explanation on the website.
