Originally Posted by
Tnedator
Hey Jeff,
Thanks for the reply. For clarification, I was not wanting to use it to find my way around, but instead use that as a barometer of how bright it was and how much it might bother me. I have a similar situation to your bluetooth LED with my phone. If I don't turn it upside down and up against a ledge where it charges, if the LED is blinking showing a received email, it drives me crazy and I have trouble sleeping. Same with the question about incandescent lights. I would have a black light to charge it, but was more wondering how much charging it would get unintentionally from the regular room lights and sun through windows, on those nights when I didn't want it charged.
Sorry about my answer if it seemed that I didn't understand your question... I totally did. Most people, who have read enough of my answers know that I can't give a quick, to the point, answer. Instead, I seem to be all over the place when answering (its an ADD thing) :-)
I think that you'll see that I did really understand, but then again... maybe not. Sorry! :-)
Tnedator
Switching tracks a bit, and a question about my home theater (I emailed you for a quote). I'm going to have a soffit around the ceiling, but it is not the angled soffit a lot of people in this thread have shown or you have talked about. Instead, it will be a rectangular soffit, that will be functional, providing additional soundproofing for the holes cut in the home theater wall for HVAC and AC, etc,, and will house the can lights and HVAC runs. So, I'm having trouble figuring out how I would mount black lights.
Tnedator
How well would multiple recessed/can lights mounted into the side of the soffit say 4" - 6" below the ceiling work for charging the mural? I'm not sure if there are blacklights for recessed lighting or how CFL's would work.
You know, most of the theater rooms that, with soffits in them, where I paint a mural, don't usually have a slanted inside. That, in my opinion, would me a plus, but isn't necessary. As long as the top of the light can peak it's head up over the trim that is in the front of the soffit, it should work fine. The only advantage to a slanted inside is that it points the light (with the reflectors) out into the room, which seems to increase the reach slightly.
By the way, I built an office last summer that I put a soffit in... and it isn't slanted on the inside either. The inside is still unfinished, so I may still put something under the lights to angle them, but the ceiling still charged up just fine.
You brought up a great idea, and one that I hadn't thought of. Putting can lights in the verticle inside might work great. You can buy CFL black lights, or just use white CFL lights... and I'll bet that would work great... if placed right. Thanks for the idea! That may help others too, when they are trying to figure out what to do.
Be careful though, with the circuit for those lights. Most black lights, and CFL lights can't have, or don't do well on a dimmer.
Tnedator
The ceiling area inside the soffits would be roughly 13' x 17'.
When did you email me with that ceiling size? Has Chris, my new assistant gotten back with you? I can ask her tonight or tomorrow.
I can't quote ceilings in here (supposed to just answer general questions)... so I will try to find your email. I am, with Christine's help, starting to finally get caught up. But, ill try and get you answered right away. Sorry if you've been waiting a while.
