AVS › AVS Forum › 3D Central › 3D Source Components › Cyberlink power dvd 10 bluray 3d help
Cyberlink power dvd 10 bluray 3d help - Page 6
post #151 of 162
I found out that the Video card was scaling the image. Once I set it to 0% the checkerboard format went away.
post #152 of 162
How is the 3D effect after scaling the image?
Are you using dlp-link glasses?
I have the Mitsu 3d starter pack with Mitsu IR glasses, and I am seeing the same kind of screen that you posted earlier. I haven't tried scaling down the image yet though.
My PS3 with the Mitsu TV plays the 3D content perfectly.
post #153 of 162
I got PowerDVD 10 Ultra Mark II to play bluray 3D on my HTPC. I am using a QuadCore, with a weak GPU (ATI HD 4650) and a Mitsubishi 73736. I set it to output checkerboard and had to scale the overscan to 0. The images I am getting from the bluray 3D demo disk were amazing.
With the overscan set at 0, I can't see parts of my desktop. Anyway to fix this without going in and scaling it back?
1080P
Not sure
I don't have problems playing DVD, or bluray from PC to TV. 3D blurays work but it shows a double image without glasses. When you put on the glasses you see one image but you can see the checkerboard output.
post #154 of 162
If the TV does not allow you to disble overscan when in 2D mode then to use the TV as a monitor you will have to continue to underscan the PC output by setting the slider at about 15%
post #155 of 162
The checkerboard went away and the 3D effect was there. However something was still not right, as I was getting a seperation of the 3D image when the object came really far forward or went really far back into the screen. I went to TMT3 and that solved the seperation issue.
post #156 of 162
You can put the icons in the center of the screen so it won't cut them off. I tried setting up 2 different profiles. One with 0% overscan for 3D viewing and one profile set to about 7% for normal use. In theory this should work but it wouldn't switch the overscan between the profiles.
post #157 of 162
I use the IR glasses
post #158 of 162
I got the Viewsonic glasses yesterday and they make the image look brighter and colors are more accurate.
You might want to try playing with switching the left and right images. I was having an issue with playing on the computer before until I switch the left and right.
post #159 of 162
I have the exact same problem as the original post.
I have a system with :
Intel Core2 2.4GHz with 4 cores
Windows 7 Ultimate
Power DVD 10 Mark 2
Nvidia GeForce 275 GT (784MB)
Nvidia 3D vision kit (Glasses and IR)
Samsung 120Hz 22" Monitor (Nvidia 3D compatible)
I play Blu ray disk, play 3D games, Everything works good.
When I put in a 3D Blu Ray and select "Play 3D movie" it tells me I have to play it in full screen and I select "OK" it goes in full screen and only black with mouse cursor.
I also have this strange thing that if I do the same in the "Media Center" Application of Power DVD, not the windows 7 media centre, the one that comes with Power DVD, it does the same, it goes all black and after a few seconds comes back saying that my HDCI is not working.
I will try the solution provided, the Dual DVI cable, but I thought I already had a Dual DVI cable.
Will let you know in my next post.
post #160 of 162
Look at your current cable connectors and see if all/almos all of the 24 pins are used if only about 1/2 of the pins are used then you have a standard single link DVI cable.
post #161 of 162
Ok, I did that and the cable was a dual DVI with all pins there. I still changed it to one that actually was label "Dual DVI" and tried my setup again.
It did not work.
When I run the PowerDVD 3d Advisor, all is ok except my Display. I will post screen shot when I get home.
My display is seen as "Syncmaster" and not "Syncmaster 2233RZ" like it is displayed in my device manager. I originally thought this was the issue so I updated the display driver with the driver on the Samsung webpage. It did not change anything. The Advisor still show all OK except Display. Nvidia control panel shows all ok even the HDCP link. I just get a black screen when I try to play 3d.
So I did what I did not want to do and installed AnyDvD. Guess what? All works now, I can watch Resident Evil in 3D.
I am sure I am not the only one ranting about that, but I spend time and money to buy correct equipment and I "Buy" the movie and the industry overzealous anti-pirate stuff stops me and forces me to buy and install things like AnyDVD. Who is wrong here? I don't have the numbers, but I bet that they spend, specially Sony, more money on all this anti-pirate stuff that they actually lose. I say Sony because the Movie Resident Evil that I was trying to watch is from Sony.
Maybe the issue is that PowerDvD and the PowerDVD 3D advisor does nto reconise my Samsung 2233RZ as a 3D display. The issue is that this is one of the fist 3D LCD available along with the one from Viewsonic. There is not that many, so I be suprise if this was the issue.
I decided to try AnyDvD because of the message I got when I was trying the movie on PowerDvD cinema mode. It seem to tell me that I was not HDCP compilante. Can you imagine if I was not trying to find the solution here, if I was not very good with software and PC and if I had not found this forum?
This makes the technology very inaccessible. I bet some of those issue also makes there way to the living room equipment world. People don't the the right version of HDMI cable or a blu ray player has an old firware... ect. Makes it impossible for people to view the great movies that producers and directors makes for us.
If there was no protection, Sony would lose what? 10 to 20% of profits? less? I don't know... I bet they pay more that that on development and support of things like HDCP and other anti pirate things. Look at the Porn industry, they have 3D movie, zero protection... are they poor?
Sorry for my rant again... I'm off to give my money to AnyDvD now.
post #162 of 162
I refrained but I was going to suggest that your issue seemed HDCP related. Shows you should always post your ideas up. I was pretty sure I had seen that posted over on the 3D Vision forums for those samsung displays.
I agree with you on the HTPC. It's tough. I mean even without 3D it's tough and not for the masses yet. I've had it with mine, I want it out of my theater.
  Back to Forum: 3D Source Components
