AVS › AVS Forum › Display Devices › Display Calibration › Sony 52EX700 white balance/ bluish tinge
post #1 of 10
Picture mode: Cinema or custom
Backlight 5
Contrast 90
Brightness:50
Colour: 50
Hue: 0
Sharpness: 0
Colour temperature Warm2
Noise reduction Off
Mpeg noise reduction Off
Motionflow Standard
Film-mode Auto 1
Black corrector Off
Adv. Contrast Enhancer On or Off
Gamma 0
Auto Light Limiter Off
Clear White Off
Live Colour Off
R Gain 0
G Gain 0
B Gain 0
R Bias 0
G Bias 0
B Bias 0
Light Sensor Off
Sony 52EX700 LED (edge lit)
This TV is excellent yet also extremely frustrating. I have one more week if I want to return the TV so I need some advice on the settings before I make a decision whether to keep it or not.
The TV is only used in very dark room.
Anyway, as reported by Cnet, home theater magazine and on AVSforums, the picture in the darker scenes has a bluish tinge to it and indeed the default custom settings with all advance feature off produce bluish tinge picture clearly visible in chapter 5 Pandorum blu-ray and other darker movies. My blu-ray is Sony SB360 set to YCBCR 4:4:4, deep color 12 bit, picture mode is standard. I've tried different settings on the player but the bluish tinge remains.
Now, the minute I turn the ambient light sensor ON, set the TV to cimena, blue-ray player to standard settings and the picture is -you could say perfect.
The settings above will look the same; however with the sensor on it is a far better picture and no blusih tinge.
The advice I need is how do I get the picture looking the same way without the sensor on
Or: How do I adjust the white balance settings (without a color meter) to get rid off the bluish tinge.
I've used HD basic and AVS patterns for hours to get the color and tint almost perfect yet the bluish tinge remains.
I can put on a darker movie and lower the B-bias to -5, which gets rid off the bluish tinge, but the picture in shadows now looks different.
post #2 of 10
You can't do anything with the white balance settings w/o using a meter. Your other option is to copy someone else's settings. Did Cnet's review not list what settings they arrived at? Did the review mention whether they were able to rid the blue tinge through calibration?
Without using a meter you should be browsing the LCD forums instead of at the calibration forums.
post #3 of 10
Greetings
Looks different because it has no blue tinge? So do you want the tinge or not?
I don't want the tinge, but I don't want it to look different. Well which is it?
Take away blue bias or add green and red bias ... same net result.
Since bias controls are just brightness controls ... you need to readjust the brightness setting again.
The gains are contrast controls.
To eyeball grayscale ... put up one of the grayscale ramp patterns and adjust the bias controls until the blue on the dark end goes away. This may make the mid range look yellow too ... so watch out.
regards
post #4 of 10
Thanks to both of you for your replies.
As far as Cnet goes, no, they were not able to rid the bluish tint out, however saying that they Never test with any of the advance features On.
Yes, I did try several settings including Cnet which by the way were so blue it reminded me of the Caribbean. The home theater magazine was better but still bluish.
So as you can tell I hate the bluish tinge.
Now to Michael, when you say put up a grayscale pattern and adjust the bias controls until the blue on the dark goes away? Do you mean to just lower the B-bias like I did or All three bias must be adjusted, in which cases is there any rule if you lower B-bias by –5 the green and red should go up approximately to??
Thank you
post #5 of 10
Greetings
Bias = brightness control.
If you turn down the brightness, does the image get brighter? No ... and it shouldn't.
The rule is ... you don't want to use test equipment so you fly by the seat of your pants and make it look right to your eyes. That is all. That's why you look at a brightness pattern again after you muck with the bias controls.
Or you go get test gear ... and learn how to fix it yourself ... or you hire a pro to come do it for you.
Regards
post #6 of 10
Now to Michael, when you say put up a grayscale pattern and adjust the bias controls until the blue on the dark goes away? Do you mean to just lower the B-bias like I did or All three bias must be adjusted, in which cases is there any rule if you lower B-bias by -5 the green and red should go up approximately to??
Thank you
If white balance settings are available w/o going into service menu, and both Home Theater Mag and Cnet can't get rid of the bluish tint using those settings, I'd suggest you exchange for another model.
post #7 of 10
Originally Posted by Michael TLV View Post
Greetings
Regards
Thank you again
Maybe the set is producing more blue in darker scenes as reported in many places,
and maybe that's the way it is however what I don't understand how every one does not see that.
I will need to make a decision in next few days "to keep or not to keep"
Thanks again
post #8 of 10
Greetings
This set would not be the first that does this. A number of samsung led edge lit units do this as well ... added to the cloudy blacks.
Most people don't notice because most people don't spend their time looking at test patterns.
Calibration of displays ... especially your own is both a blessing and a curse. The more you learn, the more you find out how imperfect things are. The longer you own any TV ... the more imperfections you will find in that TV. The trick is to figure out which imperfections you can live with and which you can't.
regards
post #9 of 10
Or find a Kuro Elite and have it pro calibrated.
post #10 of 10
Just and update to both of you. Contacted Sony Tech support who contacted his manager and they both agreed not to send a service guy to look at the TV for in their opinion it can’t be fixed. He asked me to return it to Best Buy for exchange, which I did but I took the 52EX500 LCD instead. No bluish tinge at all. Black. Despite being LCD not LED and cheaper I’m definitely much more satisfied with this TV. I loved the EX700 just couldn’t live with the blue.
Thanks again for you help.
