Help! Outdoor antenna indoor?
I have a question. I currently have 2 flat indoor antenna a CFDTV2 , and a RCA ANT1450B. Both are decent, but only get moderate signals indoors. The place where it gets the strongest signal, weirdly enough, is underneath my couch (perhaps because since my couch is custom made, we put a bunch of heat protection reflective aluminum under it).
The only issue right now is locally we have 5 HD channels, each of the small antenna's I have will only pick up 4 of them. The one missing is different on each antenna.
Since its currently under my couch, would it be ok to put the largest outdoor antenna I can fit under there? will that work at all?
ie something like DB2 antenna, but the 4" thick it says it is online is too thick. I can only fit 3"
Here is a pic of where my couch is. Its against the windows, which are actually True north. Underneath my couch is a lot of heat sheidling reflective product as there is a heater under my couch. I would place the antenna under where the red square is.
I care MOSTLY about HD channels...but if SD comes in clear enough, i'd watch some family guy on it
