AVS › AVS Forum › Audio › Receivers, Amps, and Processors › New Onkyo TX-NR5008 & TX-NR3008
New Onkyo TX-NR5008 & TX-NR3008 - Page 5
post #121 of 8413
Originally Posted by Eldiablos View Post
Yeah on the Onkyo 3008 is 2099.99 and the Denon is 1999.99. Thanks to that posted pick I am happy the Denon is 4 Ohm Certified as two of my speakers are 4 Ohms.
try to buy a Denon for 1299
post #122 of 8413
Originally Posted by Shnapper View Post
Kinda lost me.....Is it the mains or every speaker? Is it the speakers or how XT32 is equalizing your room? What mains are you using? Is TV and PS3 your only sources? I should get the 5008 soon as it is in transit via FedEx. I will listen for this tunnel effect, I wonder if you got a bad unit or not. Post as soon as you try another receiver, hopefully another receiver with XT32..Also isn't this problem fixable with a firmware update? I know the unit is new with no support yet, but if XT32 truly is a problem can't it be fixed with an update?
I returned an Integra 50.2 due to the video stutter while the OSD was active as I need the OSD to see where the unit is set. I liked the sound of it though. The 50.2 didn't have XT32, so I hope your unit was a fluke...
I'll simplify this for you. Running auto-setup and then engaging Audyssey XT32 with Dynamic EQ=Tin/Echo sound (pick some familiar music or movies and listen for it.) It makes it really easy to hear by putting the receiver into mono mode so only the center channel plays. Turning off Audyssey resulted in crisp, clear, dialog and sound.
I have a full 7.2 AV123 Rocket setup with 2 Danley DTS-10 subwoofers. Every speaker experienced this problem but the center channel was the most noticeable since that is where the dialog comes from. The dynamics of the sound also changed and was a lot softer with Audyssey engaged.
I have the receiver packed up and it is ready to go back today. I am on the fence about trying the 5008 or just trying the new Denon. I will wait to see what you have to say about yours. My box wasn't in the best of shape upon arrival so it is possible something got jarred around in shipment, but this would be the first time I've ever had a receiver get damaged in transit and I've owned a lot.
There is a song called Savior by the band Rise Against, in the beginning it is soft music with the lead singer singing for about a minute. You can easily hear the "tinny" and echo throughout the part of the song so it may be worth trying out. It was also very noticeable with Transformers blu-ray.
I honestly think I got a bad unit, there is no way Onkyo would ship these with that critical of a flaw. I noticed it immediately the first time I fired up a movie.
post #123 of 8413
Just for the hell of it, run auto setup with the subs OFF, listen to find if that clears up the issues.
What I'm saying is that powerful subs just may throw Audyssey off track.
post #124 of 8413
Does the 5008 have the relay clicks when the audio format changes that plagued the 5007?
post #125 of 8413
^ I've heard "not nearly as bad", but we now have actual owners on site here, so what say yous?
James
post #126 of 8413
Thank you much for the advice. As of right now the Denon is looking like the winner though it is made in China where the Onkyo is made in Japan. For some reason, just get that visual that the Denon will kill me because it is using low grade radiactive metal with a smidge of asbestos :O
post #127 of 8413
Thank you much for the advice. As of right now the Denon is looking like the winner.
Good receivers, but more than I have to spend
post #128 of 8413
NR3008 didn't click near as much as my previous NR3007 did with the updated firmware to address that specific issue. It also was a lot more quiet when it did click.
post #129 of 8413
Chris from Audyssey said the filters for the mains and the filters for the subs are independent and one would not affect the other.
I just dropped it off so no more testing at this point. I will wait for others to report before I decide to repurchase or look at the Denon.
post #130 of 8413
And that means what,,, that Audyssey is perfect in every way, is that what you found when you used it.
post #131 of 8413
The German Auerbach Verlag, publisher of several HiFi and MultiMedia magazines, has tested the new 3008 and discovered, that the new Audyssey MultEQ XT32 seem to have a mejor bug in its current implementation, which delivered results leaving the impression of defective speakers. They did repeat the tests in several other locations outside of their labs and concluded finally, that the older version of Adyssey MultEQ XT in the 3007 and 5007 gave excellent results, while the measurements of the new XT32 seem to result in much worse calibration. Turning off Audyssey removed the impression of defective speakers. This is been supported by feedback of several users of the 3008.
It is yet unclear, who is responsible for the disaster: Onkyo or Audyssey....
http://www.digitalfernsehen.de/news/news_957059.html
post #132 of 8413
Hello,
Wow. I cannot believe a problem like that made it past Beta Testing. While I am quite confident this can be fixed with a Firmware Update, this is definitely not the way a highly anticipated revision should be released.
Cheers,
AD
post #133 of 8413
Might be related to certain not yet known boundary conditions...
post #134 of 8413
Chris Kyriakakis, Founder and CTO of Audyssey, has already responded, that they are investigating this case.
He stated, that they tested the original unit provided by Onkyo without any visible problems...
post #135 of 8413
I assume this will be the same case with the 5008 I have on the way? If it's firmware fixable I might wait it out. However I would almost prefer they roll it back to XT if they can't quickly fix the XT32. Can this version be rolled back to XT?
I'm not real excited about he 5008 coming in the mail now LOL!
post #136 of 8413
I received my tx-5008 yesterday but haven't had a chance to hook it up, since I'm also waiting for my new speakers. I hope this can be fixed with a FW update soon.
post #137 of 8413
Here it is Onkyo TX-NR5008 $1699.99 TX-NR3008 $1299.99
http://show.audiogon.com/cgi-bin/st....AstAAAAAAonkyo
post #138 of 8413
Well, looks like I'm not crazy after all! Good luck to all new owners, Onkyo has excellent customer support and should take care of everyone. If you decide to wait for the fix do not run Audyssey setup and you will be fine.
post #139 of 8413
Originally Posted by Audiodork View Post
Hello,
Cheers,
AD
AD,
I agree with you. No manufacturer should release a component that may require an immediate update to refine a highly publicized feature. This should and may have been caught in beta, but Onkyo may have released the player anyway hoping the die hards would purchase and faithfully wait. They may have also wanted to get their product to market before Denon released the AVR-4311CI. Unfortunately, this wouldn't be the 1st time a manufacturer has done this. Has Onkyo ever done this in the past?
Willie
post #140 of 8413
Willie - The NR3007 and 5007 had relay clicking issues that they addressed with firmware updates pretty soon after they first came out which was last years models.
post #141 of 8413
jmalto,
Aufyssye MultEQ XT32 is an advertised feature that should work right out of the box and was a part of the reason I was considering the 3008 vs the 3007. I bet some will be holding off on their purchase decision until this is resolved. Did the firmware update for the clicking remedy the problem in the 3007 or just lowered the sound of the clicking?
Willie
post #142 of 8413
Note:
Audyssey, CTO Chris Kyrakakis, has just announced, that the first production run of the 3008 / 5008 has a firmware bug, which causes the stated problems. There will be an official announcement by Onkyo following, up to which serial no this problem exists. For those units affected a firmware update will be provided by Onkyo.
post #143 of 8413
Originally Posted by gurkey View Post
Note:
That is great news. Very good that it has been addressed and appears that the problem has been isolated.
Cheers,
AD
post #144 of 8413
The "relay clicking" issue wasn't one, really, because it happened only, if the user did not setup default audio modes in the units setup, thus causing the unit to hunt / search for a new mode every time the input parameters changed. They just added a convenience feature, to have this subdued in the case, this was the cause.
This matter - and its remedy - has been discussed extensively in several forums and threads already.
I do have one of the "big" Onkyos and it never happened to me...
Originally Posted by bakerwi View Post
jmalto,
Willie
post #145 of 8413
The "relay clicking" issue wasn't one, really, because it happened only, if the user did not setup default audio modes in the setup, thus causing the unit to hunt / search for a new mode every time the input parameters changed. They just added a convenience feature, to have this subdued in the case, this was the cause.
Well its not really a problem, its just the way it works. Still it will click when watching HD TV when there are breaks in the programming and switchs between 2.0 to 5.1 and 5.0, comcast sometimes drops the LFE channel. Once the Audyssey bug is fixed the 5008 should be a winners trophy on any shelf.
post #146 of 8413
That's just not acceptable. Think about it - every commercial and channel change will cause an audible click as the rcvr syncs on the different audio feed. At times, I'm a heavy channel surfer (over 100+ HD channels) and I see the audio changes on my Denon 3808ci but it's noiseless.
Scratch the Onkyo 5008 from my list. I'm down to the Denon 4311ci and Integra DTR-70.2 ..... if they're ever released.
Thanks for pointing this out.
post #147 of 8413
Please read, what I posted just before.
You have to setup default modes for each operating mode of the AVR to make it practically disappear....
post #148 of 8413
If the 5008 clicks with audio feeds, then so will the Integra.
post #149 of 8413
Guess I don't understand the Onkyo "click". My Denon configuration has AFDM - On, which sets auto-select surround mode by source. When I change TV channels, I see the rcvr changing the audio output configuration to match the detected audio in. 5.1 remains at 5.1 but 2 channel audio input is converted to 7.1 (as I've configured it) out.
During these audio changes is when I'd hear the Onkyo audible "click", correct?
post #150 of 8413
^ Essentially. Again though, you can take 5 minutes configuring it correctly to all but alleviate the issue. There's solid reasons to chase after the Denon 4311, but this is not one of them, IMHO.
James
