Originally Posted by mjf_uk
I expected it it to be really hot to touch, but it didn't feel anywhere near as hot as some other Receivers can get. Although I guess that isn't really the best way to gauge it. Thanks to Bill Mac I can now keep an eye on the temperature.
I would do something with some external fans if I could find some that were not heard from my seating position. I'm just 2m away from the 3008, so they would have to be very quiet. I was going to say that running some off the USB port would be good, but the 3008 doesn't have USB on the back, so if it is possible to run some off the 12v trigger then I'd certainly be tempted.
Yeah - 2m is close. The fans I bought are very quiet but they could be audible from 2m away in very quiet passages of movies, I think. Not sure and it's impossible for me to test it for you because of the way mine are arranged in the separate closet. It's possible to run them from the trigger but you'd have to use the Zone 2 or 3 trigger as there isn't a Zone 1 trigger on these AVRs for some reason best known to Onkyo. And if you use the Zone 2/3 trigger, you need to have some sort of programmable remote to turn on Zone 2/3 and off again when the amp goes on/off. I use that arrangement to turn on/off my Emo XPA-3 and it works fine. Not sure how you would use the trigger signal to power up the wall wart(s) but I do believe it can be done.
I do believe that these ultra-quiet PC 4 inch fans are quieter than the internal fans, so you would get a gain anyway, if you're finding the internal fans are switiching on.
Kind Regards,
Keith
Also, has it been confirmed that the current problems are specific to a certain manufacturing date?
I was presently in the market or had just received a 3008 I would be skeptical.
They only had 2 left in stock. Took the one with a completely different (probably newer) serial#. I still have to get it connected, so will give feedback asap.
I use heights not the wides but that's just my preference.
