Anyone here know if it's possible to use the Audyssey DSX mode with a phantom center or if it's only selectable when there are at least 7 speakers hooked up?
I'm using a pair of Boston Acoustics E100's for the mains and have been looking for another to use horizontally as a center. I was watching (listening actually) to the '04 version of 'Phantom Of The Opera', and 'Across The Universe' on BD and decided that my current center isn't quite up to the task of matching the E100's.
In other words, I think the E100's creating a phantom center sound significantly better than my current center.
Until I place another E100 horizontally as a new center (or find something that works equally well), is there a way to enable Audyssey DSX without a physical center channel? I like the effect created by the Wides.
Max
Max
