AVS › AVS Forum › Audio › Receivers, Amps, and Processors › New Onkyo TX-NR5008 & TX-NR3008
New Onkyo TX-NR5008 & TX-NR3008 - Page 20
post #571 of 8416
I think half an inch of clearance on the top would be clearly inadequate. I would go 2" at a minimum if you have plenty of easily/directly accessible venting to the front and rear of the unit. I designed my setup from the very beginning around the idea that my audio/video receiver would be an effective room heater.
post #572 of 8416
So far, no decoding problems on my 3008.
post #573 of 8416
I have no issues with TrueHD or DTS-HD on my 3008. I have confirmed this with both my PS3 Slim and my Samsung BDC5900.
post #574 of 8416
If I'm running 4-ohm speakers with the Onkyo 3008, is it best to set the receiver at 4-ohm or leave it at 8-ohm???
I heard that setting it at 4-ohm actualy reduces the power output..
Anyone know the answer to this??
post #575 of 8416
Leave it at 4 Ohm.
Indeed the power (watt) goes down but also the heat output and power use.
I allways run on 4 Ohm even i have a mix of 4 and 8 Ohm speakers.
Never had any problems and a much cooler running receiver.......
post #576 of 8416
Unless you changed your rack ventilation with only a 1/2" of clearance, stick to the 4 ohm setting. If you ran the 8ohm setting on five or seven 4 ohm speakers in that rack; I expect you may have a new 3008 complaint post in the near future
post #577 of 8416
Hehehe. It's actualy not in a rack, it's on a shelf with all sides open to air, only the top part is covered 80% with only 1/2" clearance because of a shelf on top of the receiver...
And the Onkyo don't seem to have much vent holes on their sides, most of the venting comes from the top of the receiver, so I might be forced to place the receiver some place else, where it can breathe free air up top...
Here is a picture of my TV stand (on the bottom left is where the amp will be, that's an old picture with an old Marantz SR-5003 receiver I used to own before my Pioneer Elite SC-37 and before the incoming Onkyo unit...)
There is 8.5" between the bottom shelf (where the receiver will be) and the middle shelf where my center channel speaker is.
So the Onkyo unit is 7.81" high, which leaves about 0.69" clearance on top.
post #578 of 8416
That doesn't look so bad,
post #579 of 8416
Originally Posted by CobraPA View Post
I've mailed them just now. I plan on calling them tonight as well. I am also trying to get one of their HD Radio docks (UP-HT1) to work and it seems to have similar issues to the network and usb. Plugged in to the universal connector and it seems to not be visible at all. Selecting PORT shows 'not compatible' (or something similar) and then switches to 'All channel stereo'. But the '>' seems to do nothing, as do the other controls mentioned in the manual related to controlling the HD radio box. Maybe the unit is dead, or maybe the dock connector isn't enabling like the net/usb weren't. I don't know yet.
I've received responses from Onkyo USA to both my questions. Just now in an email about the network startup problem. They say they are aware of the problem and are working on it, and to check the website for updates. This is good news, as when I called them two days again, their response the following day was that they were still investigating.
They responded to my HD Radio problem as well, telling my the HD Radio was bad and I would need to replace it.
I've got to say, the one or two day response to email and phone calls is refreshing. I'm not used to hearing much back when I try to get help from tech support.
CBdicX, our report may have helped. I gave them a detail description based on how you told me the network would not start, then start when the cable was pulled. When they called me yesterday they where still investigating, but the email today says they are aware of the problem. I take that as a good sign.
Some additional details:
While on the phone with Onkyo a couple days ago, talking about the network not enabling problem, the rep keep suggesting I disable DHCP. I would ask if I should then setup a manual IP address. And he would say something like 'no, it will get an automatic address then...' Which didn't make any sense. But thinking that maybe there was some sense in there somewhere, I turned off DHCP tonight to see what would happen (without doing a static network config), letting the settings default. The net and usb menus now come up after the 30 second startup delay without hanging! Of course, the network doesn't work, but I bet with a static IP it would be ok, so there's a workaround. And if you then turn on DHCP again, the network comes up fine...
post #580 of 8416
Originally Posted by Furmantation View Post
Yes, hooked up via HDMI. Tried several cables. I've tried two different Blu-Ray players (a Samsung and an LG). Neither worked except if set to PCM. Also tested both players on a different Onkyo (508 I believe) and TRUEHD and DTS-HD worked great. It almost seems as if the 5008 I have doesn't understand the incoming signal . . .
just FYI -- a very similar bug occurred with many xx10 Denon models last year. It only happened with specific Blu-ray players (LG and Samsung were the most common) but, when bitstreaming TrueHD/DTS-MA, there would be silence... set to lossy audio or PCM, and no problem.
Other BDP's worked fine with no issues... it's probably a firmware bug that only crops up with specific BDP's.
post #581 of 8416
Just had the pleasure of speaking with Onkyo Customer Support. It's clear why everybody complains about their customer service: just plain awful. The rep on the phone (Mark) says that he's made the 5008 work with TRUEHD and DTS-HD, although for the life of me I couldn't get him to get out of his chair and try it in the lab. I've ordered a replacement unit, let's hope it helps.
Received the new unit, and DTS-HD appears to be working! Haven't tested TRUEHD yet. Running the firmware update now, it will be interesting to see if things continue to work following. VSP Writing 39% . . .
post #582 of 8416
It's odd that some units are working fine while others are plagued with bugs. I wonder if there was a bad batch. I hope the new one works out for you.
post #583 of 8416
DTS-HD still working after the firmware upgrade. Off to finish configuration and test TRUEHD.
post #584 of 8416
Anyone here with a Popcorn Hour C-200 that can verify if DD TrueHD and DTS-MA work with the Onkyo via bitstream?
I'm not getting any sound for HD codecs, but lossy ones work fine.
post #585 of 8416
When no sound is heard, what does your Onkyo display as the audio input and output (can be found by pushing the home button)?
post #586 of 8416
Once the movie starts, the Onkyo switches to "All Channel Stereo" mode and there is no sound. Info reports the audio as "Unknown".
post #587 of 8416
Same symptoms I experienced. Replacing the receiver solved the problem.
post #588 of 8416
I tried this and a static IP address does not help on my NR3008 with the Sep 17 firmware. If you leave network control enabled, then the network doesn't seem to disconnect when you turn the receiver off and on, I suspect because it never shuts down the network. If I do, the only way to restart seems to be to pull the cable.
post #589 of 8416
Makes me still wonder, why nobody seems to rave about the Audyssey MultEQ XT32 implementation in the new Onkyos.
The first Denon 4311 users seem to feel differently...
post #590 of 8416
I ran the Audyssey setup yesterday with a 5.1 setup. I only used 3 points of measurement and it balanced my room really well, even though the room is not acoustically clean (couches and speakers behind objects.) I was pretty impressed for a first run.
post #591 of 8416
same with my using the Audyssey set up, first run seems good. My wife did come in and asked what the weird noise was? then she started a load of wash....smile.
post #592 of 8416
Does anybody here output DVD @ Source Direct to the receiver, for the Reon-VX to upscale? Do you add a bit of edge enhancement?
I can't decide if I like Low or Mid better but I do generally like Reon's edge enhancement -- it's amongst the most tasteful I've ever seen. Of course I have it upscale to 1080p/60 and I use the Source Direct setting on my Pioneer BDP-94HD, and 480i output on my Sony BDP-S1000ES.
post #593 of 8416
After again spending hours of trying and resetting the router i have a working Network connection, WITH OUT Network Control active
This is my working setup:
1) disable DCHP
2) disable Network Control
3) put in the next numbers in the manual setup, but DNS server must be
the one you will get from your ISP.
See Picture.
4) disable DCHP in the router
And for me this worked
Its fast, it connects without any problems, it connects after standby, it connects after power lost, IT CONNECTS . !!
And without the power eating Network Control setting..........
I did get some connecting problems with my PC's, as disableling DCHP in the router will make the PC's not connecting.
You do need to alter the PC settings also to manual and not DCHP !
post #594 of 8416
So how do you 5008 owners like your Onkyo? I have my decision down to that one and the Denon 4311. You mention build quality in that thread and some people get their panties in a bunch.
post #595 of 8416
[b]1) disable DCHP
I'm expecting a firmware update from Onkyo for this problem, as they say they are working on it. That's interesting that disabling DHCP makes it work. I've been running with network control enabled for now (plus, then I can fire up the beta iPad app and control the Onkyo remotely. )
I'm generally happy with the 3008, although it's only been a week and I just hooked up 5.1 speakers this weekend. I added an HD radio yesterday, and some of the digital music sound profiles sound really good with 5.1. The HD radio / iPod dock combo works well, and allows you to view the iPod/iPhone music and playlists on screen. And the remote allows controlling both.
The Audyssey setup seems to be working well now (using the firmware upgrade from 2 weeks ago.) So far I'm pretty happy with it.
post #596 of 8416
Eldiablos,
I frequent the 4311 thread also and I liked your comment about not calling someone's wife or girlfriend ugly.
I personally believe that all the AVRs in the $1,500 to $2,500 (MSRP) are comparable in build quality depending on how each perspective buyer defines build quality.
I had the TX-NR5008, Yamaha RX-A3000 and the Pioneer SC-37 on my short list in addition to the Denon, but ruled out the Yamaha (prefer Audyssey) and Pioneer (not 9.1 or better) and have been teetering about the Onkyo (excessive heat). I know the heat may not be an issue long term, but the amount of heat this unit puts out can't be good for the internals, so the Denon has a slight leg up at this time.
I was hoping for more comments from owners in particular 5008 owners, but there seems to be very few of either. I wonder if the early problem (though fixed) with MultEQ XT32 scared off perspective customers. I know it got my attention.
Willie
post #597 of 8416
Originally Posted by bakerwi View Post
Eldiablos,
I had the TX-NR5008, Yamaha RX-A3000 and the Pioneer SC-37 on my short list in addition to the Denon, but ruled out the Yamaha (prefer Audyssey) and Pioneer (not 9.1 or better) and have been teetering about the Onkyo (excessive heat). I know the heat may not be an issue long term, but the amount of heat this unit puts out can’t be good for the internals, so the Denon has a slight leg up at this time.
Willie
LOL thank you. But that is what that thread is starting to feel like. You point out one negative about the receiver and people start behaving like you have insulted the honor of their receiver. I just come from the school of thought that if you put down 2k on a receiver it shouldn't be cheap feeling. I want features and decent construction. I'm greedy like that. I don't think anyone should be crucified for pointing out some negatives about a product as long as it is in a constructive way. But at the end of the day, it comes down to what a person wants from a receiver. Some people are just putting someone down because they feel red is their favorite color when others think blue is. I think we can respect people's different opinions without having to attack them.
Fact is for the 4311 to make it's price point it had to sacrifice something. After looking at a comparison with the 4810 they sacrificed, chassis, speaker posts and power supply. Now will this make a difference? It all depends on what you are going to use the receiver for? If you use it as a preamp it rocks and an easy buy, but if you plan on running 9 speakers off of the receiver alone, it probably will strain. Denon has also had a rep for bad network cards.
The flip side is the Onkyo 5008. This mother is built the way you would expect for $2000. It's a tank and 17lb heavier. My guess is most of the weight is in the power supply. But comes the next issue. All those power supplies mean heat. Heat is bad for components. I have been reading the 5007 owner thread as I feel the 5008 is the 5007 just with HDMI 1.4. The 5007 has had some issues with HDMI boards. Don't know why maybe the heat is causing the issue but the receiver gets great performance reviews on professional tests of it's ability. I do however, want a receiver that lasts longer than 6 months. I have read that Onkyo customer service is really bad on several different forums.
You and I seem to be in the same boat. We are not afraid to question shortcomings of any receiver because we don't want to pay $2000 and not feel satisfied. I just hope some owners of the 5008 can give you and I some feedback so we can decide
post #598 of 8416
I do hope that the FW update will make the "problem" receivers work like it should, with DCHP active and Network Control disabled.
Even i have it working now, disabling DCHP in the router makes my PC start and close down a lot slower.........
post #599 of 8416
you might want to check out the new Anthem receivers
post #600 of 8416
Eldiablos,
Willie
Hello,
Willie, the 4311 Thread is sort of beginning to feel like the OPPO BDP-83 Thread all over again to me. From the vantage point of someone who uses outboard Amplification for all Channels, the Preamp Only Mode on the 4311 where the Amplifiers are shut off made me pause about keeping the TX-NR3007 I recently purchased.
However, I really am a huge fan of Reon after having it in the TX-SR875 I owned prior. Also, I use Martin Logan Electrostatic Speakers (Vantage, Stage, Vista) so adding DSX really is not possible due to the size of the Speakers I am using. I do wish Onkyo would allow the simultaneous use for Width and Height Channels with DSX, but again it really is not applicable for me.
Cheers,
AD
