I believe the 70.2 equates to the xxx8 series..... the Integra xx.3 equates to the Onkyo xxx9s.
post #7531 of 8416
12/20/11 at 4:26pm
In addition to resetting Processor, I have checked firmware. All my cables are clearly marked and banana-ed in. If this matters when running audyssey before Sub calibration you immediately hear the pop before Sub engages. Not sure if it matters on that but I don't recall every hearing it before. Today I am grabbing a new power strip I am hoping will help possibly clean up the signal (tripplite). Is this possibly a ground loop? Maybe the few extra watts are triggering? I have 2 protectors, on and on them 2 subs, 1 5008, PS3, 2 360's, Samsung 59D6500, Samsung HDTV Box, D-Link Giga Switch. Is there a general best practice for what pieces should be on what power strip? Is it best to have everything on one strip?
, you should have a better idea of what is going on. It's possible the AVR is faulty but you mentioned that the pops were not present when you played music, which seems odd. What is different when you play music as opposed to a DVD? Are you using a different DSP for example, or running in stereo mode or not using the sub or what? There has to be a difference or you would hear the pops when playing music. Try to then use the DVD in the same settings as you used the CD and see what happens. Eventually, you will pin it down to something and know whether to send the unit back or not. Good luck.
