Originally Posted by theater_lover
Onkyo TX-NR5008 Amplifier Capabilities...
Hi, I have a question about running some 4 Ohm, low sensitivity speakers on a 5008.
I recently switched to a pair of 4 Ohm, 84 dB mains. As such, I switched the internal setting to 6 Ohm and below.
Now when I push the amp to levels that let the neighbors know what I am listening to, I have had the system shut down in protection mode a couple times. This is without running a center or heights. My hope is that all I need to do is just not go that loud (say keep it at 72 instead of 75) and avoid buying an additional amp.
My question: Is each channel independent in the receiver, or do they all work together? Meaning, if I add a center (also 4 Ohm, but 89 dB) and heights, will the system kick into protection mode at an even lower volume as it is now driving more speakers
More speakers and higher SPLs are a good recipie for pushing a receiver into protect mode, but the middleman is usually excess heat.
How is the cooling around the receiver and how hot does the case get right after it trips out?
& then turn on the amp with the start button on the remote make sure you have the 12 volt trigger cables in the proper places
