Originally Posted by
Franin
What I find good is when calibrating the projector without the lens and then with the lens and there is no change in results that's a good indication in the quality of the lens.
This is an interesting comment as I read on a UK forum recently about a HD950 (RS25) owner who had an ISF calibration done (very well respected calibrator over on the UK forums). The owner has a cineslide and a Mk4 lens. The calibrations for both modes was quite different. He is extremely happy with the calibrated results (after being unsure as to the worth of getting it done). Apart from a small issue with a 'shadow' in one corner due to the cineslide being slightly too far to one side, he is very pleased with the lens. I understand he is moving the cineslide position this weekend to resolve the shadow isse.
Results below for those interested.
ISF 16x9 "WITHOUT LENS" SETTINGS
CONTRAST = 4
BRIGHTNESS = -6
GAMMA CUSTOM 1 CORRECTION VALUE 2.5
COLOUR TEMP CUSTOM 1
Custom Colour Temp 1
GAIN RED = 0
GAIN GREEN = -8
GAIN BLUE = -25
OFFSET RED = -3
OFFSET GREEN = 0
OFFSET BLUE = 2
CMS SETTINGS : HUE, SATURATION, BRIGHTNESS
RED : H = 12, S = -18, B = 1
YELLOW : H = 0, S = -41, B = 27
GREEN : H = -20, S = -42, B = 28
CYAN : H = 5, S = -47, B = 35
BLUE : H = -27, S = -9, B = 4
MAGENTA : H = 0, S = -26, B = 12
ISF "2.40:1 USING LENS" SETTINGS
CONTRAST = 4
BRIGHTNESS = -6
GAMMA CUSTOM 2 CORRECTION VALUE 2.5
COLOUR TEMP CUSTOM 2
Custom Colour Temp 2
GAIN RED = 0
GAIN GREEN = -3
GAIN BLUE = -12
OFFSET RED = -1
OFFSET GREEN = 0
OFFSET BLUE = 2
RED : H = 0, S = -20, B = 40
YELLOW : H = 0, S = -38, B = 60
GREEN : H = -15, S = -34, B = 60
CYAN : H = 0, S = -28, B = 55
BLUE : H = 0, S = -20, B = 50
MAGENTA : H = 0, S = -20, B = 48
I'm planing on renting an i1 Pro soon to redo my HD350/IscoII/VideoEQ Pro calibration and I plan on taking two sets of readings with and without the lens to see what results I get. I will likely only calibrate with the lens in place though as this is the vast majority of my viewing (unless I have enough time to adjust a spare memory). I would expect there to be some difference between results, though whether they are big enough to be noticable with the naked eye is another matter.
