AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › Cylindrical A-Lens Owner's Thread
Cylindrical A-Lens Owner's Thread - Page 21
post #601 of 623
Originally Posted by coolrda View Post
Just had to snag this pic posted by fellow videophile W.Mayer of his dual Barco/Isco 1.25 4K3D projection system. He could quite possibly have the finest projection system in the world. A true spectacle.
That is very impressive indeed.
post #602 of 623
Hi Mark. So had I but he discusses in detail on another couple threads about the $15k Isco cinemaDLP 1.25 A Lens and the superiority of it when he compares it to the Isco III. From bouncing around and reading his posts it sounds like his complaint with the distortion which he demonstrates is what we call pincushion. If I understand him right he says the 1.25 doesnt have pincushion and focus is prefect at the extreme edges as well. Is this a fully geometrically corrected lens? Getgray can comment here but he stated both have the identicle glass. Maybe Mayer is seeing the distortion because his new projector's need the 1.25x lens due to the 1.896 AR. Remember these are 17:9 projectors unless run at 2160x3840.
There is nothing magic about the 1.25. I stand by what I said in the other thread, although I decided it wasn't good use of my time arguing there. The 1.25 will have the same geometry issues inherent with a 2 doublet A lens. I believe part of the reason he was seeing light drop off was he was vignetting and didn't know it. If the ray pencils are partially obscured at the lens it does not result in an image shadow on screen, but a light drop off as he described. As the 1.25 has less expansion, it will have less artifacts from expansion by definition. But those should be trivial and for the most part unmeasurable. Problem with that Sony and a IIIL is it has a fat beam at the physical exit point of the chassis. Someone that knows how to ensure no vignetting needs to check where it will, and will not fit.
post #603 of 623
And that alone is the only thing is has to offer IMO. $15K?
post #604 of 623
To be fair, it is substantially larger, so vignetting will be less of an issue and you could use it at shorter TRs. Of course it doesn't really cost that much, depending on where it comes from.
post #605 of 623
Can I assume there is an additional row to this theater? It would be a shame to put that kind of money into it and sit against the rear wall, where are the rear/side speakers?
-Sean
post #606 of 623
The other thing to consider too is that the ISCO III being 1.33x, was designed to work with HT projection where the ISCO 1.25x is really only made for the 2048 units used in D-Cinema. You could use a 1.25x in the home, but you would need custom scaling where the 1.33x lenses will work with the simple letterbox and 4 x 3 modes.
post #607 of 623
And that and what Getgray said was why I think he was complaining about the Isco 3L in the first place. Ive seen it in front of several true 4k projector an the pic is stunning. There is no way that even the finest most perfectly aligned 3 chipper beats the Isco 3L when it comes to chromatic abberation. I seen several people comment on the CA when the Isco is in the light path. Of course you do, because your stretching he picture 33% so you notice it more at the edge. Now take the ISCO away and guess what? You have CA you never noticed before. That's why there's nothing like a one chip DLP. It still my favorite, but I cant give up the contrast of my RS40. The other thing people confuse/interpret the increase in pixel density and the smoother picture as a loss of focus, when in fact the picture is better. Viewing true 4k for the last four CES and true 8k this last one was a revelation. The picture is become more analog/organic which is huge benefit. So one thing the top commercial and residential theaters all have in common, Cylindrical Anamorphic Projection and that will continue with higher res projectors.
post #608 of 623
A massive PLUS ONE on that
post #609 of 623
A-lens or not decisions decisions........14`.2" throw 1.97 TR.
JVC RS65 (X90) 3m white 1.2 gain screen 108hours Calibration at 250hrs. Resized only.
Arts Sim HT5000 + A-Lens 4.25m screen
post #610 of 623
You could combine the JVC and anamorphic lens. I have an RS55 with an Isco 3 on a 135" wide 2.35:1 Enlightor 4K screen - my first row is at about .85 SW and I love the effect of the e-shift and anamorphic lens at that close distance. In my tests it seemed that the benefits of e-shift diminished once you reach 1-1.2SW depending on the quality of the source and the screen material.
post #611 of 623
Thanks for the reply Hogpilot
Your A-lens is giving you more lumens needed for your 3.4m screen which is good if needed but what else is the A-lens doing to improve the picture?
If extra lumens are not required, menus visible all good but is the picture quality something you can photograph to show A/B comparisons or is it more like a perceptual improvement?
The 6million odd e-shifted pixels and no SDE remaining without the A-lens and lower lumens degrade picture quality enough to buy the A-lens?
Just trying to understand, i can purchase an A-lens with a 2 week full refund if needed but to save the hassle hear i am, extra lumens would be nice as lamp ages but really asking about picture quality..
post #612 of 623
It's notoriously hard to appreciate the difference an A lens can make just using photographs (you need the full res available otherwise it's a waste of time), and usually only a demo can provide what's needed.
Gary
post #613 of 623
I'd say the lumens are the biggest contribution. I haven't had a chance to A/B with and without the lens in my final setup (zoom vs. lens). I have yet to notice any extra CA, but the Isco is about as good as they come in this respect so no surprise here. What's your viewing distance?
I would love to take some pics, but I'm currently deployed to the Middle East until July, so unfortunately my theater will be sitting and waiting unused until then Sorry I can't offer more help on this...
Only you can really answer that question, but I'll offer this up - when I was A/B'ing the Enlightor 4K screen material against the Seymour AV CenterStage XD, the 4K clearly had the edge in terms of lack of screen surface visibility, yet my eye was constantly drawn to the image on the XD because it was noticeably brighter. So I guess what I'm saying is not to underestimate the benefit that the extra brightness will give you. Whether or not it's worth the cost...everyone has a different answer as to how much money is "enough" - hence the rather heated debates on the subject in this forum
I would say that extra brightness contributes to PQ significantly. Since you have the 2-week grace period, I'd recommend you give the lens a shot and see if you like the result. If you don't, at least you're not out any money.
post #614 of 623
Gary
+1! Couldn't agree more...
post #615 of 623
Thanks for being there for us, Hog. Fly safe. May I use your Isco 3 while your away?
post #616 of 623
Thanks Hogpilot i do sit 1SW back, looks like i will have to see for myself. Prismasonic Finland must be confident giving 2 weeks grace if disappointed, i will check again though.
post #617 of 623
Sure, just fix the inop slide for me while you're at it and we'll call it even It's a re-branded Panamorph slide, which may be part of the problem...
post #618 of 623
Be sure and start a thread with your impressions, please. I'd sure like to hear them, and I'm sure others would.
Motorized, I presume.?
post #619 of 623
Yes indeed. And I didn't mean to insinuate that Panamorph makes sub-par equipment; quite the contrary, my personal opinion is that their stuff is by far the best bang for your buck in terms of price/performance ratio.
However I don't think that the slide was meant to handle the heavier weight of an Isco 3, hence my suspicion that the motor may be burnt out. However it may be more than that - the unit won't even turn on, so it may be something on one of the small circuit boards under the cover. I meant to send it away to a guy over on Curt Palme's forum so he could look at it before I left, but I ran out of time so it will have to wait until I get back. Or maybe I'll just trade up to a CineSlide...
post #620 of 623
With your JVC is there a need for a slide with these menu options?
Manual quotes
Anamorphic The video images are projected after being enlarged in the vertical direction of the panel
resolution. This setting is used when one uses the anamorphic lens to enlarge them in the
horizontal direction.
If a 3D signal is fed in when Anamorphic mode is set to A or B, Anamorphic mode is
automatically turned Off.
Settings: A, B, Off [Off]
A: Video with an aspect ratio of 2.35:1 is enlarged in the vertical direction of the panel resolution and then projected.
B: Video with an aspect ratio of 16:9 are displayed by reducing them in the horizontal direction, without changing their size in the vertical direction.
Off: Used when watching video images other than those with a 2.35:1 aspect ratio while using an anamorphic lens. 2.35:1 video images are projected without any changes. (Black bands appear on all sides)
post #621 of 623
Manual quotes
I haven't personally played with that feature (my Lumagen Radiance does all the processing), but yes it sounds like you are correct, no need for a slide if you want to use the JVC's built-in scaling functions.
post #622 of 623
Am i right in thinking with an A-lens I leave my pic in 16:9 mode (mid zoom) let the A-Lens fill the screen gaining 12,500 on/off CR (X90) + 25% Lumens 425?
Cine4home table:
-------------Zoom IRIS Lumens X70 X90
High / D65 Max Closed 370 53000:1 80000:1
High / D65 Min Closed 310 69000:1 105,000:1
post #623 of 623
Cine4home table:
You'll maintain the CR, but you won't "gain" lumens - you'll still only have the quoted number of lumens, you just won't lose any to the overspill you'd have if you were zooming.
The only time you "gain" light output from using an anamorphic lens in numerical terms is when you're measuring light off the screen in foot-Lamberts, since that measures light per unit area.
