AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › Cylindrical A-Lens Owner's Thread
Cylindrical A-Lens Owner's Thread - Page 4
post #91 of 623
Thanks Scott. Used the S&M disc's sharpness pattern and readjusted for astigmatism. The picture is surprisingly much sharper. The horizontal lines weren't in focus. Now the horizontal line is the same as the vertical. It a noticeable difference, even with movies. It gives the appearance of having better ANSI contrast and increased depth of picture.
post #92 of 623
Does anyone know what price range the new Schneider 1.33xLE falls into? And what does "LE" stand for?
post #93 of 623
I don't have pricing yet. It is about the size of the M lens but it's elements are a plastic material. It was shown at CEDIA last year nameless IIRC. My guess is LE is Light Edition. I understand it was meant to be competitive with the lower priced lens options. I would not get your hopes too high that it will be "cheap" though. I expect the other possibilities hitting the virtual shelves earlier or about the same time to be competitive with it. Quality wise, I'm sure it will have their professional lens mechanics, as for optical performance, we'll just have to see how it compares.
post #94 of 623
Someone picked up a IIIL off Ebay this week for under $3k. I was watching it but the guy changed it to a "buy it now" and poof it went before I saw it change. I don't think he knew what it was (worth) now. Someone got a *really* good deal on that puppy. It's the only IIIL I've ever seen hit ebay I think. Very rare in any case.
post #95 of 623
I did a little digging and it apparently will come packaged with a motorized Kino-Torsion for around $4.5K. The Kino-Torsion alone for the 1.33M has an MSRP of $2350, so the difference of $2150 would make for a pretty hot price on the lens. Then again, the lens by itself might go for more.
post #96 of 623
4.5k is apparently correct, with torsion.
post #97 of 623
That is a good price
post #98 of 623
Very hard to find those types of lenses on eBay.
post #99 of 623
Very hard to find those lenses used anywhere, I Was lucky and found one a couple of years ago and payed 3000$. And I will never sell it!
post #100 of 623
I am hoping for a new level of pricing (around 2K+) for future products. What Alan mentioned earlier seems promising and the thought of a new Schneider lens at a lower price point would be great. If either option pans out, I'll be selling my trusty Panamorph 480 and sled.
post #101 of 623
Im hoping many more jump aboard the CIH route.It will be good to see many more members onboard. Once you get the taste of CIH you do not want to go back.
post #102 of 623
The setup instructions mentioned previously are in the back of our CineSlide's manual.
www.techht.com, downloads link, CineSlide manual link....
This is exactly what I was looking for. Going back over my projector install using plumb bobs to perfect alignment, I realized I am good in almost every way except somehow about an inch off horizontal center!
If I remember correctly (it's been a while since i set up my UH480), it is not advisable to use the projector's horizontal lens shift for alignment, meaning I need to manually move my projector in order to dial in alignment horizontally, correct?
post #103 of 623
Yes I went through the article to on the Isco setup, its very good, Ive never seen this before.
post #104 of 623
Being perfectly aligned is a proper goal, but if the PJ is already mounted, and has horizontal shift available, I wouldn't go ripping down a PJ instalaltion over an inch, unless it was causing a problem.
post #105 of 623
I should update those instrucitons. I have some improvements on the method, just havent had time to do the editing...
post #106 of 623
Please do that and let us know in this tread when you do...
post #107 of 623
OK. Registered owners first
post #108 of 623
I'm holding you to it.
post #109 of 623
I meant registered *CineSlide* owners . We need to upgrade you.
post #110 of 623
Cooldra,
How did you go with re-adjustment of the astigmatism correction on your ISCO III?
post #111 of 623
It sure is Frank but by time it reaches our shores through a local distributor it will no doubt cost a whole heap more than exchange rate would dictate. Be nice if it was made here.
post #112 of 623
I guess its the case of not going through the local distrubutors. There is a place us Australians can get them.
post #113 of 623
Originally Posted by CAVX View Post
Cooldra,
Yes. I did refocus. Removed lens and refocused projector. Had my son at the projector while I stood at the screen. Did the same after lens was mounted. I used the S&M test disc. The difference was considerable. My original adjustment was nice and sharp in the vertical plane, not with the horizontal. Soon as they were both dialed in the image just popped off the screen. Huge improvement. Only problem now is I desperately want a new projector. I will wait to CEDIA announcements then decide on my next unit.
post #114 of 623
Sounds like we're in the same boat as I currently own a BenQW5000 too and like you have found with the ISCO III, the anamorphic lens has way better optics than the projector
post #115 of 623
Whats a list in order of projectors with the best optics and is there a visible difference when you use one?
post #116 of 623
Im on that boat too Mark Im looking for another projector. At the moment Im looking at the JVC 950 but Ive just noticed there is also the 990. There is still plenty good projectors out there
post #117 of 623
I guess it also depends on the price range. I was looking at the Marantz and was told not to bother with it as its not good as the JVC. The Marantz has awesome optics from what ive read.
post #118 of 623
All I will say on that is that my next 1080 will have to out perform the current unit I have or I will move to another technology even though I do like DLP.
post #119 of 623
A 3 chip DLP Mark?
post #120 of 623
A 3 chip DLP Mark?
I'd actually like one of those single chip LED models.
