--This thread has been notably altered--
Alright, so I have a bit of a challenge for you guys. I hardly know anything about speakers that go in the ceiling (or in-wall for that matter) but after much argument, this is what my parents said they want in their living room because they want nothing on the floors. I barely convinced them of the subwoofer. They drilled the holes for wires in the places I told them and basically, I figure the following is what I need...
Ceiling speakers are usually circular and commonly around an 8" diameter so that's what I told them it will most likely be. They now expect that so I hope I wasn't wrong. The back speaker pair will obviously need to be able to tilt or at least be built already tilted at a predetermined angle. The side pair needs to be facing down as they will practically be right above.
The only thing about the in-wall speakers is that they need to be square.
I presume the right way to go about this is up to $400 per ceiling pair, $500 for a L/R front speaker pair, $300 for the Center speaker, and up to $500 for the subwoofer. A little more for whichever of those three would be okay, if there's something that'll be found that's well worth it, relative to whatever is for less. If you're wondering about a receiver, we already have one
It's pretty good - a Yamaha. I didn't check if it has calibration (as it isn't mine), but regardless, it's not of concern for what I need help with.
Suggestions for any part of this setup are really appreciated. Thanks in advance, sincerely.
**Some more info might be necessary that I didn't think of so please ask if it helps
-David
It's pretty good - a Yamaha. I didn't check if it has calibration (as it isn't mine), but regardless, it's not of concern for what I need help with.Suggestions for any part of this setup are really appreciated. Thanks in advance, sincerely.
-David
I'd really be grateful. It's kinda getting to the point of urgency.
