AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz SR5005 / Marantz SR6005 HDMI V1.4 ABT AV Receiver Owners' Thread
Marantz SR5005 / Marantz SR6005 HDMI V1.4 ABT AV Receiver Owners' Thread - Page 22
post #631 of 704
This issue pops up from time to time on both Denon and Marantz models, generally resolved at a repair facility.
post #632 of 704
I have a Panasonic 85K bluray player that is direct connected to an overhead projector for 1080p video and 8 analog cables to a Marantz SR5005 for hi def audio. I tried going through the Marantz for video but the distance is too great for an HDMI cable (35 feet) and I was losing signal. When I went directly from the player to the video with the same 35 foot player the signal is fine.
I picked up the Panasonic 310 with 2 hdmi outs. I can run a 25 foot cable to my projector for 1080p and a 15 foot hdmi cable to the Marantz for hi def sound. I am told I should get superior sound as opposed to using analog cable (8) to the Marantz.
I want to run these two bluray players into the Marantz, the 85K using 8 analog ins and the 310 using hdmi in so I can compare the sound of each. In each case the hdmi goes to the projector which has two hdmi inputs. Can this be done.
John
post #633 of 704
Sure. No different than connecting any other two sources, although you'll also want to try an optical cable from the 85K as you likely get better results as using the multi channel analog disables Audyssey.
post #634 of 704
Thanks for the response. I initially used the analog connection to get hi def audio (using the players audio processing) though I understand that this doesn't use the Marantz audio processing.
I will go ahead and set up the second player and run a side by side comparison.
I still have to figure the menu set up on the Marantz to do this. Perhaps call the second blu ray player satellite (I don't have one).
John
post #635 of 704
John
I was able to install the new bluray (Panasonic 310) with 2 hdmi out whereby I am using hdmi to my Marantz in lieu of 7.1 analog. The result is a noticeable improvement in sound quality using the hdmi which uses the Marantz for processing instead of the player.
John
post #636 of 704
any other result would have been surprising...
post #637 of 704
I'd like to know which subwoofer any owners of a SR6005 have or could recommend. There are just so many to choose from. Thanks!
post #638 of 704
I looked at this amp about 6 months ago and it was going for around $600. Now it's over $1000 again. My brother bought one then, I should have grabbed one. I wonder why it went back up?
post #639 of 704
Hello everyone,
I am new here and I have a question to ask. I am trying to connect two subs to my marantz sr5005 with a y-splitter rca cable.
Will it makes any differences if one sub has a lef/right and the other has a lef/left? Will it work even both lef is in different channels?
post #640 of 704
Not sure what a "lef/left" is but just connect one of the two split cables into each of the "L" only inputs on each sub.
post #641 of 704
Sorry I misspelling the lfe with lef.
I have two subs which one is from martin logan and the other is from klipsch.
The klipsch has a lfe-in from the left.
The martin logan has a lfe-in from the right.
I just connected the 2 subs according to their lef-in channel and all I hear was noise coming out of the subwoofers.
I turned off the receiver and unplug one rca cable from the y-splitter but theirs no bass. However, if I unplug the y-splitter, there is bass.
Can it be a bad adapter? I just purchased that adapter today too.
Once again, thanks for the help.
post #642 of 704
from the sub out preout, connect the y-splitter... connect from the y-splitter to the lfe in on both aubs...
post #643 of 704
Your description is a bit confusing. With both subs powered on, and the "Y" ends connected to the LFE inputs as Chris notes, pull the cable from the AVR sub preout and rub your finger over it. Do you hear static coming from both subs? If yes, then there's no issue with either the subs or the cable. If not the issue lies with one or the other.
Additionally, on the Martin Logan, make the following settings:
Crossover: Bypass
Phase: 0 degrees
Low Pass Filter: 200hz (max)
Level: 12 o'clock
with similar settings on the Klipsch.
post #644 of 704
I sure have re-read it for confusion and I am sorry for all the confused sentence.
Thanks for the advice Chris.
What I meant was when I connected the two subs to their lfe-in and the Y-male connected to the sub pre-out of the receiver. All I hear was noise.
Next step, I remove one rca cable from the y-splitter female side and only have one sub connected. I don't bass or noise.
Next, I remove the y-splitter and just connected one regular rca cable from the receiver pre-out to the sub lfe-in and the bass works.
Thanks again for all the help. I will try what you have suggested Chris by connected the 2 subs to the y-splitter and rub my finger over it to see if I hear noise.
post #645 of 704
The problem is solved, thanks for the help. The y-cable was not fully inserted I think. Now, Just have to re-arrange the 2 subs for good bass.
I do have a question regarding a sub with 100W rms and 200W rms. What level will you like set for both sub. Should I set the 200W to a quarter and leave the other one at Half leveled?
post #646 of 704
I would connect one at a time and run Audyssey until you have both set at the same level. Somewhere around 0 or above. I think I got mine set to +2.5 (or so) and ended up around -6 after connecting both.
post #647 of 704
Wonder if any of you people are using a DAC in between your source and the marantz and do you notice any in sound improvement? Sources like media players.
I am interesting in purchasing a DAC.
post #648 of 704
In order to use Audyssey you'd still have to use the DAC in the AVR anyway, so as others have found, much better audio quality using Audyssey rather than using an external DAC or one in the source (eg. Oppo).
post #649 of 704
I have a DAC hooked up to my AV7005. As good as the AV7005 already is in Pure Direct - and so is the 6005 for that matter which I have in a 2nd setup - I felt the DAC helped things out in the vocal range which is where I think this line of Marantz sounds a bit thin, but it wasn't enough that I don't bother to use DAC.
post #650 of 704
Hi all.
This is my first post in avs. This thread convinced me to purchase the Marantz sr 5005. One characteristic that is different from threads of other avrs is how almost all of you discuss its sound quality, instead of its features. And I have to agree. This avr is by far the best sounding I've had in a very long time, coming from teac pro logic, harman kardon avr 200 and yamaha vs10 home theater in a box. And I'm having a blast using it in a bi-amp config. Lack of networking, flac, and other contemporary tech will be easily mitigated by getting a decent blu-ray player with that kind of support
I decided to forgo the sr 5006 even when it was available at the same store solely because the newer unit does not have multi-channel pre-out, and it was more expensive.
One frustrating problem I had was that my 5005 cannot handshake with my LG BP 620 blu ray player. I did every permutation of power-up sequence and tried different hdmi cables to no avail. I eventually buy another blu-ray player, a bare-bone, dirt-cheap LG BP 120. And it worked like a charm. For all of you out there, I hope you've never come across HDMI handshake problems with any of your device. Few things are more vexing than to excitedly get home and install your equipment and find that it does not work.
I just hope I'll never come across that dreaded pop of death issue.
post #651 of 704
I'm looking at 5005 or a 6005
Any big differences in the two?
How hot do they run ?
Are the 5006 and 6006 any better just did not like the port hole?
post #652 of 704
Anyone?
post #653 of 704
Hello everyone,
Thanks for the help on my previous post.
I have another question regarding distance cables run and female-to-female for cable extension.
Is this ok with signal sending from the amp? Or I will suffer lots or less of signal loss? And will this degrade the subwoofer bass?
I already have a 15 fts cable but it is glued to the wall and I don't want to rip it out and get a long cable. I have order a 12fts cable from monoprice and returning it will be a hassle since it is shipped from US to Canada.
Thanks all,
Nhsice
post #654 of 704
Hey gang, I've got an SR6005. I'd like to use a record player for my LP's. Do I need some sort of Orr amp or can I just plug it into one of the other inputs? Thanks !
(new to the vinyl thing)
post #655 of 704
the difference i saw is that the 6005 has a better onscreen menu, overlaid over the pic during play, and 10 watt per channel advantage. the 5005 i have does not run hot at all. noticeably warm though.
post #656 of 704
The 6005 doesn't have a dedicated PHONO input so unless the record player comes with it's own pre-amp, you'll need to add a phono pre-amp similar to this one before plugging into any of the analog inputs on the 6005.
post #657 of 704
Hi everyone,
I don't know if I should start a new thread regarding the issue I am having currently but I rather keep it here.
I am encounter an odd issue with volume on my sr5005. Whenever, I increase the volume on the knob or from the remote control, the db shows on the screen will go from -80 to -70 then back to -75.
I have reset the processor but it is not helping me. I want to ask if any of you guys have the same thing happened to you?
post #658 of 704
So you're saying you rotate the volume knob from -80db to -70db ... stop at -70db and the volume display returns to -75db? Does this happen at volumes where you can actually hear something?
post #659 of 704
No, this does not happen at all when I turn the knob from -80 to -79 ( this is when I can hear something). The odd thing is 25% of the time it does not exhibit the problem and the 75% it does. Even, it is from -70 to -60 then it revert to -63.
post #660 of 704
Sorry I forgot to include this. If I keep rotating the knob, it exhibit the same symptom. Let says if I want it to be -60 for my reference listening. the volume will display -70 then -73 when I keep turning the knob clockwise. It also does it on the volume from the remote control.
