Yes. I had problems before the firmware update.
Using DHCP out of box configuration.
No Network Control.
No static IP assigned.
Would say "cannot play" or "no server" infrequently after standby.
Enough to notice something wasn't right.
After the update, it hasn't happened - the same way.
I think "cannot play" and "no server" are normal occurrences due to Onkyo (I think), Pandora and vTuner servers (or channels themselves) being unavailable, thus "cannot connect" or "no server" as a result.
If your issue is persistent, refuses to connect at all, or only works (after a firmware update) only by unplugging/plugging in the Ethernet cable - that is a big problem.
If it were me with problems like that, I'd contact Onkyo and let them know/troubleshoot. If that doesn't help, then I'd return it for exchange - after I've verified it isn't related to my cables/hardware (router) s /settings (router).
Originally Posted by
RichB
Did you have network connection problems prior to the update?
- Rich
