AVS › AVS Forum › Audio › Speakers › Need help ASAP ...PLEASE!
Need help ASAP ...PLEASE! - Page 2
post #31 of 46
Originally Posted by brian6751 View Post
They do not come with wire. Get some 12awg from monoprice.com
Although you can't go wrong with 12 ga, if your runs are short yo can get away with smaller.
post #32 of 46
You have a fairly large room, to push 90db (so/so average sensitivity) speakers to good levels just below or near reference you'll need more power.
I'd get a mid-priced AVR with PRE-OUTS so you can add an external amp (Emotiva XPA-3 comes to mind) if you find you need one... and you probably will... no doubt it will sound better even at lower volumes... a beefy amp will really allow your speakers to open up and show you what they can do, bass, imaging, detail all increase...even at lower volumes. I run 93.5db sens. Rocket RS8850s from 14' and it made an insane difference once I added a 200w x3 Emotiva to them.
No Pre-outs= no possiblity to upgrade!
post #33 of 46
Good info!
On the Denon 1911 it says it has:
Enhanced power amp assignment
high current/discrete amplifiers
Pre Amp output is listed as "sub" (not sure if that limits it to just a subwoofer)
Assignable amplifier configuration of back channels
Pre Amp outputs for multizone
So I am a bit lost, does this or does this not mean I will be able to add an amp (upgrade my power).
Thanks for the info.
post #34 of 46
Originally Posted by dmercer3 View Post
Good info!
No it only has a pre-out for the sub...Yamaha and Marantz maybe Onkyo offer 5.1 pre-outs in some of their mid-priced AVRs. No AVR power section can compete with seperate amps so don't put all of your money into an AVR that has a lot of power compared to AVRs. It's a waste of money... You can get a $400-500 AVR with a $500 B-stock Emotiva XPA-3 (that weighs over 50lbs and runs 3 channels @ no less than 200w with all channels driven). And you'll totally kill any $2000 AVR out there....
Personally I wouldn't even look at AVRs without pre-outs...the upgrade bug is a feirce little creature...and you don't want to regret your puchase and have to sell your new AVR because you can't upgrade to seperates..But that's my opinion only.
If this a dedicated HT room?
post #35 of 46
You want a receiver that has preouts for the front 3 channels, not multizone.
If you want a Denon that's going to cost you a whole lot more (~$800) to get one with the proper preouts.
You may want to look elsewhere like the Onkyo RC180, 707, 807 or the new 708 and 808. You can get a Yamaha with preouts under $400 if you stick to last years models. The RX- V665 and 765 are pretty heavily discounted right now. If you want a 3D model you start with the RX-V667.
Onkyo 707
http://www.accessories4less.com/make...eceiver/1.html
Marantz 5003
Yamaha RX-V665 & V765
http://www.newegg.com/Product/Produc...-196-_-Product
http://www.newegg.com/Product/Produc...-197-_-Product
post #36 of 46
Onkyo 707
Marantz 5003
Ok, hopefully its not to late to change my order because I do put a lot of weight on being able to upgrade, and can see myself wanting the amp.
With that said, I looked at the above AVR's and I think i can rule out the marantz because it only listed 3 hdmi inputs. I need at least 4 inputs.
Can you guys point me towards a less than 500 AVR with
amp pre outs
3d
4+ hdmi in with 1 out (with arc)
and the obvious features and codecs included in my previously selected denon 1911
So which one of these has those things?
Pioneer VSX-1020-K
Onkyo 608 (708-808 are out of my price range)
yamaha 667 (if i can find a decent deal under 500)
any other?
If I find one tonight ill try and cancel the 1911 before it ships.
post #37 of 46
Onkyo 707
Marantz 5003
anyone?
post #38 of 46
Yamaha RX-V667 is the closest I've seen to your price point with the features you require, but its $50 above your budget.
http://www.google.com/products?q=Yamaha+RX-V667&aq=f
Maybe Sony has an offering for you. Check Sony's website.
post #39 of 46
i found a place i can get a discount on the 667 (420 bucks total)
should i switch my denon 1911 to the yamaha... about to make the change and hoping its the right move.
post #40 of 46
Make sure you can get a full warranty from that dealer. If they're not authorized Yamaha dealer you could be screwed.
I can't make the Denon vs Yamaha decision for you. You have to decide which features are most important.
post #41 of 46
thanks, i appreciate your input. Its electronic expo. i believe they are legit.
post #42 of 46
You have trouble making decisions hu!
Both brands make great AVRs... the heavier one with the most power consumption will most likely have the better amp section and output more power..which will be much less than what the specs say with all channels driven... unless you spend a lot more.
If you plan on getting a 3 channel amp don't worry too much about the AVR's power as it'll end up only powering 2 or 4 surrounds depending on if you have a 7.1 or 5.1 system.
Besides that....if it has the options you want...get it...if Pre-outs are a must for you (they are for me) don't buy an AVR without them....If you're not sure go to best buy and see if you can find similar models...as listen to them on the same speaker so you can hear how each sounds... amps in AVRs and seperates do have slightly different sounds from model to model and brand to brand.
I say...buy that one...yeah the black one.
post #43 of 46
Yep, they are legit. Great price!
Ah yes, the EMPLOYEE promo code!
post #44 of 46
man, i sure have NO idea what i would do without this site and all of your help.
Seriously, you guys saved me on this one. Thanks.
post #45 of 46
The bill is in the mail...
post #46 of 46
not sure what to do in this case.
I received my first of a set of polk monitor 70 speakers today from ups.
The box was obviously not handled with any care, but I was hopeful there would be no damage. Took the speaker out to realize the feet of the speaker had scratches on them (which I dont care about) but could indicate these speakers have been used. Then the part I do care about, right at the middle of the front panel of speakers there are two obvious scratches, about 1.5 inches each. This is in the front silver part of the speaker panel, behind the mesh grill.
The problem is newegg is out of these speakers and I do not think I will get a replacement. Polk 70's are either out or out of my price range everywhere. Am I stuck with speakers that arrive scratched up and possibly used?
FYI, I cannot test them because I will not receive my new receiver for about a week.
What to do?
  Back to Forum: Speakers
