post #1 of 1
I have a Samsung LNT4665FX/XAA running the latest firmware. I have had no problems with it until this week I turned it on and got this...
I removed the back cover to inspect the capacitors which seems to be a common problem with this model but all looked fine nor could I see anything else obvious.
Through searching I have stumbled across a few other people with the exact same problem but no solution.
Does anyone know what is causing this. If it's the main board or the display or what.Any input would be appreciated.
