Originally Posted by
ricabullah
Perfect.
What is missing here is downsampled PCM streaming and why we don't use MPC-HC/FFDSHOW together with Haali for them.
So my final choice will probably be:
WinDVD for bitstreaming,
MPC-HC/ffdshow/haali/ReClock-bitperfect mode- for PCM streaming
(24/16 automaically selected via direcly linked filters: haali > reclock)
If you don't like MPC' s internal video filter, use ArcSoft video filter
As for PCM:
I forgot haali doesn't support 96.
So you have two options:
Opening just from the file: (i don't like it because it doesn't recognize mpls)
Select Arcsoft 2.125 filters under external filters (arcsoft demux, arcsoft audio decoder hd, arcsoft video)
This time you have to select 5.1 every time.
Or
Select MPC's internal gabest filters and ffdshow.
This time you have the chance open DVD or from the file but you have to select the bithdepth manually.
I think the second choice is more handy and more functional.
I hope somebody will write codes to run it automatically some day.
_ __ _ _
