AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Vizio XVT3SV Series NO PRICE or Coupon talk
Official Vizio XVT3SV Series NO PRICE or Coupon talk - Page 67
post #1981 of 4768
Just picked one up at Costco. They had 4 left.
Got it home and set it up. I think the picture looks great right out of the box, but I'll try the cnet settings tonight.
My only complaint is the remote is very thick and the slide out keyboard feels a little rough.
XVT553SV firmware version VIZIO_C1.2.22_RC1
Assembled in China
post #1982 of 4768
Originally Posted by alig2003 View Post
Had mine for 2 days, and noticed the same thing on turn on, sound is weak and uneven with a slight wavyness to the picture. Haven't noticed if it goes away with time, because i have always just changed the channel on DTV DVR and it goes away.
Firmware is 1.2.22rc1, which i haven't seen mention before
I need to contact vizio CS. I really suspect this is a non-issue related to some kind of hdmi handshaking going on. A different cable (which I don't have at the moment) is also a worthy test. I have never had this last more than thirty seconds.
post #1983 of 4768
I finally pulled the trigger on the XVT473SV Vizio from Costco based on the feedback in this thread. I paired it up with a Sony BDP-BX57 and so far I'm very happy! Still tweaking the settings on the Vizio, and I choose a hardwired network over wi-fi and Netflix viewing has been fantastic. BTW, this is my first HD TV!
post #1984 of 4768
2 weeks in and I noticed 3 magenta spots on my screen! I don't think there are any fixes for this type screen flaw but does anyone think there is a fix before I take it back to replace it. ? At this time, I would not even think about getting a different brand or even a different model! This tv rocks!! THANKS a Million!
XVT553SV lover
post #1985 of 4768
Question for those owning the 55" set (as I imagine the answer will be slightly different for the other size sets):
What portion of the stand is structural support vs. for preventing tip-over? The ultimate question is whether some of the stand could be trimmed/removed if the tip-over issue were resolved through other means?
The reason I ask is for a DIY mounting project (where the backing wall can not support a traditional mounting bracket). The other option is to remove the stand entirely, but this set does not have a flat bottom so it would require other work-arounds.
This question would probably be easiest to answer for someone who has removed the stand for mounting and can take a look or even post some pictures of the bottom surface of the stand.
Thanks in advance!
post #1986 of 4768
I use my PS3 and Xbox 360 for video playback quite a bit. I make sure Game Mode is off when I am watching videos, but must have it on while I'm gaming. I have a Logitech universal remote, and was curious if anyone knows if the Game Mode option for the Vizio has a direct command to turn it off and on? I'd like to create separate activities for watching videos on my consoles and playing games, so I don't have to manual go in and turn Game Mode on and off each time. Thanks guys!
post #1987 of 4768
Just a heads up: Was at BJ's tonight and saw the XVT553SV and the XVT3D554SV side by side. I immediately noticed that the 554's screen was glossy (almost like a plasma screen) and produced rainbow starburst patterns around all of the lights reflected in the screen. The 553 was of course, a matte finish and did not produce these effects at all. Since I want a matte screen, I'll stick with going for a 553...
Also, I checked with the service desk and they did not have any 553's in stock. The code they had indicated that Vizio was having problems delivering, i.e., a shortage.
The pricing at BJ's was extremely attractive (almost as good as Dell's). I *think* Vizio is having an instant rebate program until the 26th.
post #1988 of 4768
Has anyone had a loss of audio and distorted PQ on startup?
It seems to be only on HD sources and lasts only about 30sec before it fixes itself.
post #1989 of 4768
Yes, when I last turn it off with the input selected to my cable box (HDMI connection) there is a 30 sec (maybe less) or so delay just for the audio. If I had it on my cable coaxel input direct there is no delay. Go figure!
UPDATE 10/06/2010: After more use I'm noticing the audio delay is not there all the time and when it is it's about 10-15 seconds total before sounds are working. This from the Scientific Atlanta cable box and using HDMI out to HDMI 1 on the TV.
post #1990 of 4768
Hi all,
I am loving the 42 so far, and I just took it to the next step: I am getting Polk monitors and figuring out which receiver to get. If you wouldn't mind taking a look at this thread and helping me out, that would be great! http://www.avsforum.com/avs-vb/showthread.php?t=1295106
post #1991 of 4768
ours finally came today, i have it just sitting on the stand right now. What im curious about is how long i should wait until i power it on. It was sitting on a cold (below freezing) delivery truck for many days and i just don't wanna mess it up.
Its been inside for ~3 hours so far
I got my plasma in the summer and brought it home myself so i didn't have this issue then
post #1992 of 4768
Glad it arrived. Sounds really cold where your at.
Three hours would be a minimum, and six would be just about right. There is a lot of mass there as you know, and the screen is probably the most critical part.
Just give it a few more hours and you will know you did your part.
Tom
post #1993 of 4768
The "white flickering line" at the top of the screen (during some broadcasts) has been mentioned. The user's guide mentions a "zoom 1" setting in the Wide menu, and that should fix this, but I can't find the zoom 1, or zoom 2 settings anywhere.
Has anyone found these, or are they just another "missing feature" in the user's guide?
post #1994 of 4768
Tom
yep good old upstate NY, was snowing this morning actually
post #1995 of 4768
What Plasma do you have?
Let me know your thoughts after your new display defrosts...
I'm looking at this display, currently have Pioneer 5070 Plasma.
Also looking at some 60" Samsung, as well as 55" Samsung & LG.
post #1996 of 4768
I have a 50 in Panny G20, the 55 Vizio is going in a different area of the house where a plasma wouldn't work, way too much light
post #1997 of 4768
ok so i must be missing something but why cant i change the backlight setting? it just jumps over it every time, all pic modes
Cable box - HDMI
post #1998 of 4768
Cable box - HDMI
Turn off the light sensor and you can change it.
post #1999 of 4768
Cable box - HDMI
Turn off "ambient light sensor" under "advanced picture."
post #2000 of 4768
The Vizio support page stated that if you were having audio issues to check the HDMI audio output source of your cable box or DVR. (assuming you are using HDMI cables as your source) If you can find out how to get into the diagnostic menu for your cable box check to see what the HDMI audio output is set on, Vizio says it should be CDM or L-CDM. If you can't, call your cable provider and see if a technician can come and look at it. I have the same issue and I believe it has to do with a handshake issue between my DVR cable box and the television using HDMI. My output was AC3 and unfortunately can't set it to anything different due to the firmware version of my cable box. My local cable company is delivering a newer cable DVR hopefully this evening. My television acts just fine using different cable inputs other than HDMI cable.
I'm no expert and certainly don't know that this will resolve the issue, I hope so because I love this set. AV science forum is IT BABY!
post #2001 of 4768
Thanks, i think i figured it out at the same time you both were posting,
Did some tweaking of the settings, liking it so far, will run it through the ropes this weekend
not a bad upgrade
from this - Panasonic Tau 32 in Flat Tube TV + some crappy sony HTIB
to this 55in Vizio XVT3SV + JVC BA1 Soundbar
post #2002 of 4768
I'm on the verge of buying the XVT553SV with only one issue holding me back - does the TV properly display 24fps content (5:5 pulldown) or not? The CNET (Aug 2010) and Home Theater (Nov 2010) reviews both state the TV uses 3:2 pulldown on 24fps source material that results in visible judder/hitching. I've seen user reviews claiming 24fps material is processed and displayed properly. Somebody suggested that the made in China units had the problem, but the made in Mexico units properly handle 24fps. Was this a problem that was resolved by a firmware update? Does anybody know for sure that 24fps source material is properly processed (5:5 pulldown) on the XVT553SV?
post #2003 of 4768
I wanted to buy this TV, but I looked at it in Sam's club, and I could not get it to look good. I fiddled with the settings and even tried CNET's configuration, but it always looked worse than the Samsungs right next to it.
The blacks weren't as black, and everything look muddled compared to the bright Samsung image. I'm sure the samsungs are setup to show well, but that's the whole point.
I really want to buy it since it is a good deal and gets good reviews, but the bottom line is how it looks to my eyeballs.
post #2004 of 4768
The bottom line is indeed how it looks to your eyeballs but NOT one that's on display with who knows how many times the feed has been split to reach all those tv's running. All the reviews are great for a reason, it's not like Vizio is running around paying off these websites to give rave reviews. And what about our personal reviews here? They surely count don't they? Pick it up and get it home, I guarantee you it will look 1,000 times better in your own surroundings with a proper High Def signal running thru it
post #2005 of 4768
BRAVO - - - well said ...
Tom
post #2006 of 4768
The Samsung is always going to look better. That black glossy screen really makes a difference. I know, I tried it before the Vizio. Problem was to get the nice bright picture on the Samsung I had to have the backlight and contrast set to 95+%. So as that set ages there isn't going to be much room for adjustments. Plus the Samsung didn't have Variable audio out with the internal speakers on (I attach a powered sub to that and it makes the TV sound great) And thier PIP was useless. The Video streaming was ok at best. It didn't support a lot of codes and I use a Popcornhour for that. And the sound, if you use the TV sound it is terrible. Sounded like everyone was talking into tin cans.
I have had the Vizio for 3 weeks and I am pleased with the picture and that is with the backlight at 30%. I have a very bright room.
post #2007 of 4768
I have a question on my 553. I have noticed that when the TV is cold (been off for several hours or more), and I first turn it on, that that audio is real hit and miss or juddery for about 10-20 seconds. Almost as if it is warming up or something. I called Vizio CS and they had me try a different input (vice DirectTV) on the next startup, or, turn on the DTV box first and let it warm up prior to turning on the TV. I've done both and it did not make a difference. So this means that the TV's audio is broken, scratch, hit and miss for about 10-20 seconds (like it is cutting in and out) when the TV is first turned on from a cold state.
Anyone else experience this?
post #2008 of 4768
Are you using HDMI cables? Check to make sure the HDMI audio out on the cable box is set to CDM. Look at my post #2000. Try a different input, RCA or anything other than HDMI cable for your signal source, the picture will look like crap compared to HDMI. Do this before you shut it down for the night then see if it does it the next time you turn it on. You will likely need to go through the set up again.
I don't have 3 posts so I can't put up the Vizio URL. On the Vizio support Q&A page you will find....
If you are using a cable or satellite box, this can happen when you change to or from HD channels. This issue could be caused by a setting inside your cable or satellite box.
To change this please access the menu for the cable or satellite box and change the audio out setting to PCM or L-PCM.
I have this issue as well but the cable company could not provide me with a new DVR until Monday. I had no issues once I used a different input method so I am confident this is the problem. I'll post again once I get a PCM capable cable box/DVR.
post #2009 of 4768
I checked, and do not have the option to change audio out setting on my Direct TV DVR box. I am using HDMI cables. Like I said, this only seems to happen when the TV is cold (has been off for at least 6+ hours)....otherwise the audio comes right on perfectly when I turn the TV on...
post #2010 of 4768
I just picked up a 432SV last night at Walmart, watched a free movie on VUDU last night and it was impressive.
