AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Vizio XVT3SV Series NO PRICE or Coupon talk
Official Vizio XVT3SV Series NO PRICE or Coupon talk - Page 103
post #3061 of 4768
Originally Posted by SharksFan98 View Post
Yes, the logo is one of the changes with the newest firmware update.
As far as the color settings go, the numbers should be about the same for you. We all have the same screen model basically...the larger TVs are just your screen scaled up a bit.
I noticed that they added Blockbuster On Demand.
post #3062 of 4768
I just returned from the 2011 CES.
Regarding the V logo - It's new and appears to be part of a new branding effort regarding their implementation of the "Smart" & Internet connected TV.
Some of the things discussed:
RVR or Random Vizio Reboot - they state awareness of the issue and think the latest update will address.
Firmware - they released a new firmware (hence the new logo with the V). This I believe introduces their new look and direction regarding the connected TV platform. Based on the comments from Vizio - should be good things coming.
Also discussed the fact that 1) the firmware seems to update randomly - meaning that everyone seems to get the firmware at different times over a long window and 2) there is no way to actively select the option to force an update (or check) or not accept a firmware. They explained the randomness - they "controll" the deployment based on Mac addresses and other attributes (geo/ip data?) when the unit phones home. No definitive response on point 2 - but acknowledged it.
New Features - The new "V" logo is a hint they are actively working on the App and Internet connected platform. They mentioned USB is "activated"... and with an upcoming firmware release, even more features will be available ... can you say "Skype" via a Vizio branded cam... yeah!
Remotes - new remote will have the keyboard on the back (rather than the slider style). This makes it slimmer and easier to type and hold. Definite improvement.
New Models - 5 series will replace the current 3. The 4 series is 3D and uses polorized lenses similar to Real3D. Very nice.... but best part, based on the comments - the same app and features on the new models will be available on the current 3 series... if this holds true, would be a huge gesture from Vizio for their current customers. I think this fact will definitely help word of mouth and build brand loyalty...
post #3063 of 4768
Can anyone post a pic of the new "V" logo?
post #3064 of 4768
It's the silver "V" at the bottom of their website www.vizio.com
post #3065 of 4768
It's not the best image it's more silver in color than this image shows
post #3066 of 4768
just wanted to post some pictures of the "first" start up HDMI problems.
first 2 are messed, and 3rd just after it stops being jacked up.
post #3067 of 4768
Freaking awesome reporting Trance! Thanks!
The word "blooming" didn't happen to come up in your short conversation did it? ;-)
post #3068 of 4768
Yeah...I won't be using the Blockbuster App anytime soon again.
See my quick review: http://www.avsforum.com/avs-vb/showt...3#post19780663
post #3069 of 4768
Looks like your backlit is set to high, lots of clouding.
post #3070 of 4768
Took my second try 55" XVT back yesterday and purchased a Samsung pn58c550 (Plasma).
I couldn't be happier! (no start up problems, no blooming...no locking up on me) and absolutely flawless picture.
I'll never buy a Vizio again.
I hope you guys have better luck with them then I did with Vizio. I really wanted to like the tv but both TV's just had WAY to many problems for a BRAND NEW tv.
post #3071 of 4768
Quickly going over the Amazon reviews for that model suggests a lot if people can't stand the buzzing from that set. I have freaking dog hearing so that eliminates a lot of plasma sets for me lol. I hope you have better luck than you did with the defective Vizios that you had . We wish you the best.
post #3072 of 4768
Hi everyone and thanks for the great thread. I just went and picked up this TV yesterday. Quick question. I've got the remote all set up to control my DirecTV box and control the volume for my onkyo receiver. Is it possible for this remote to power on/off my receiver as well as the DirecTV box? Thanks!
post #3073 of 4768
Originally Posted by Tom the Piddler View Post
Have you tried the Jag Wheel to try and turn the set on?
How do you turn the set OFF?
Have you received the newest firmware? Vizio_C3.2.3_RC3
What devices do you have hooked up to the 553?
OTA or cable by coax?
Etc, etc, etc...
If or when you call Tech Support, they are probably going to have you change the batteries out in the remote and return it to IR status. From the manual: "Open your Slider to expose your VUR10's keyboard. Press and hold the Q, P, and SPACE keys for approximately 10 seconds. Release all keys and remove the batteries from the remote. Once removed, wait 3 seconds before reinserting the batteries."
Is the Vizio logo orange in color?
You have done what they will probably get you to do next - unplug the unit, wait 30 seconds, plug it back in.
Can not recall offhand a unit not coming on as you described, either in this thread or the RVR thread.
You might be the first in these threads with the set not starting up as yours does.
So a call to Vizio tech support would be in order.
Please keep us informed, as the thread can use the info for helping others and problem solving.
Tom
ps: I'm a slow writer, so by time I get this posted, someone else may have helped you. :-))
Thanks for the reply! Interesting points, I hadn't considered that it might be the remote. I had not tried the Jag Wheel in these instances... Before I call support, I will definitely try to power on the tv that way first... and if that works, clearly there's a bluetooth issue with the remote.
As for your other questions... My devices are Comcast Cable, Sony Blu Ray Player, and that's it. I do have the latest firmware. This all started after I got that firmware, btw... The logo's not orange.
Thanks again, I will reply again with more info when this happens again.
post #3074 of 4768
Originally Posted by joshman211 View Post
Hey RX7,
Yeah, So I have the second set and the blooming is still present. It does not seem as bad on this set, Im using the same settings and I do not get big halo's around on screen displays like I did with the other set. I messed with it all night and while it is better then the last one I still cant stand the blooming. I watch alot of horror movies and movies with dark scenes and if I keep this set I will just focus on this issue forever. So they are both going back. I think I am gonna get a Panasonic G25, I know about the issues with the rising blacks etc but Ill make do. It's a shame cause I really do like this set but for the content I watch I just cant deal with it.
I used to have Panasonic G25 and the floating black issue was too annoying so I had to return it.
I currently have 47XVT3SV and consider it to be a better choice.
post #3075 of 4768
i got my xvt 553 6 weeks ago and love it. color accuracey is right on proccesing is fantastic and flesh tones are just right.the lg and the vizio shre the same backlighting technology
post #3076 of 4768
Hey RX7,
I'm sad to say, if I can convince my wife the hassle is worth it, we may be returning our set as well. We were watching "Inception" last night. There were a bunch of dark scenes where all the faces had the "Angelic glow" blooming effect. For the most part, the movie looked stunning... but then..... yuck! I'm not sure I can handle it. I think this really is an amazing "bang for the buck" set but I think the much more expensive Sony HX909 or NX810 are in our future
post #3077 of 4768
To make sure we are on the same page, the VIZIO logo I'm referring to is in the bezel at the bottom/middle of the set. Should be kinda ORANGE when the set is OFF, and turns WHITE when it is ON.
The logo will blink ORANGE to WHITE for a few moments when the power is restored (plugged back in). That's the set's software is checking things out before starting up after a power interruption. Can also occur if the system is getting into trouble as it will shut down the set, do the ORANGE and WHITE blinking for several minutes, and restart itself back up. Vizio refers this to the "WATCH DOG". This and the RVR thread refers to it as part of the Random Vizio Reboot ( RVR ) scenario.
The remote... when you reset the remote, the remote goes into IR mode, eliminating the BlueTooth pairing. Everything will work as normal in IR mode, but you will have to point the remote in the direction of the lower left hand corner of the set where the IR sensor is located. You will need to pair up the remote to the set's BlueTooth connection after your satisfied the set responds well to the IR mode.
Hope all goes well.
Tom
post #3078 of 4768
try these settings picture mode; movie / backlight;51/ brightness:51/contrast:45/color:39/tint:1/sharpness:6/color temprature..gain:red127/green129/blue118..offset...red128/green133/blue132..advanced picture are as follows. smooth motionff( this works great when watching hd or blu ray you wont get the soap opera effect switch back on for football etc.) real cinema mode n/a with smooth motion off./noise reduction off/color enhancement off/adaptive luma :low film mode: auto/ smart dimmingn. hope that helps
post #3079 of 4768
Can we get a list of movies and chapters/scenes within that movie where *Blooming* rears its ugly head? Assuming most owners are using the same settings, it could be a convenient way to pop a movie in and test a new set or an exchanged unit to see if 1 is better than another.
post #3080 of 4768
This is a shot that clearly indicates blooming even straight-on. Those who do not have significant blooming -- how does your start-up screen compare to this?
post #3081 of 4768
Can anyone confirm for me that their bluetooth audio works with VIA? I was streaming Netflix last night and could not get bluetooth audio to work. I use a pair of Motorola bluetooth headphones and they work great when watching Dish Network via HDMI1.
I also noticed that the newest firmware update (C3.2.3_RC3) seems to allow a "sticky" bluetooth audio setting. I used to have to turn bluetooth audio on everytime in the Vizio menu, but now once I set it to On, it stays that way. A very welcome change in my book.
post #3082 of 4768
Thanks for the pic's. Thought I was back in the 1960's there for a moment. :-))
Do hope you and others get this start-up problem resolved soon, as I can see it can be a very concerned situation to have.
Tom
post #3083 of 4768
I have no blooming and my TV definitely does not look like that on start-up.
Keep in mind that it is impossible to judge picture quality and/or problems through a digital picture, especially something like blooming or bleeding.
A camera exposes for the entire picture to bring out the dark areas, so if you have small bright areas, those will be overexposed, thus making a problem seem worse. As an example, the "V" is a blown highlight in his picture, and yet he says that in actuality it is silver in color. This is an indication that the camera blew out the V since it had to expose for the entire dark screen. This in turn also made his corners look a lot worse than it probably is.
That being said, his backlight might still be a bit too high like someone else mentioned.
post #3084 of 4768
I agree to some extent that a digital photo may not be a best way to judge. However, it can still be a good indicator of uniformity -- one can clearly see non-uniformity in illumination in the shot, especially close to the corners.
BTW, the picture settings, including backlight, have no effect on the start-up screen.
post #3085 of 4768
pgm, if you haven't already, please post your current picture settings
post #3086 of 4768
I'm not sure if I just missed this feature earlier or if it came with the new firmware, but...... have you guys noticed now that on certain widgets (along the bottom of your screen) there is now small up-down arrows above and below the widget, which indicates that you can now use the up-down buttons on your remote to scroll through different sub-widgets without opening it up entirely...... was this always there??
For example, on the Accuweather widget, the up-down arrow will allow you to scroll through the temperature readings for the different cities you stored in your Accuweather app, without actually opening up the entire app. Man, that is slick.
Vizio's entire implementation and presentation of internet apps makes my Samsung's internet apps look archaic by comparison. For those who have seen other companies internet apps, are there any setups as good as Vizio's?
post #3087 of 4768
pgm
My set looks similar to the pic, but with the original screen logo. Probably what we are seeing is meant to be part of the start-up scene. But as soon as the set fires up, past the start-up scene, all is well. We have almost zero blooming (credits).
Tom
post #3088 of 4768
Yeah it stinks and its a really hard choice given the price of the set. I think if the majority of the content that I watched was I guess brighter if you could say that such as comedys and animated movies etc.. then I would be fine with it. But if you watch alot of movies with dark scenes and you have blooming then your gonna have to make a tough choice. I havent seen the models your talking about but I was looking at an LG that had local dimming and was lucky to see it in a dark enviroment and I did notice that it had similar blooming as well. It looked a little differant then the effect on the Vizio but the same for the most part.
post #3089 of 4768
I'll have to check this as I haven't used mine since before the firmware update. Prior to this, they worked great, other than the setting not sticking which it is good to hear has been 'fixed'.
I have the Vizio headphones so one would assume they at least tested with these.
post #3090 of 4768
Mine looks like that, except with the old logo. It looks to me like all the LEDS are full on when the set is turned on and a few seconds later they dim properly. At least, that's how it works on my Chinese 47 inch set.
Do yours all stay on at full brightness? If so, I'd say something is wrong.
