Originally Posted by stenhunter
Not that I'm aware of :| As far as I know you can use a USB flash drive to display photos. I've not actually tried this yet though since the USB port is on the back and well it's mounted to the wall. My arm stopped being skinny enough to reach between the two years ago..
Originally Posted by DSulls The USB ports aren't completely on the back (the way that most of the other ports are) they're more on the side-back. Unless your wall mount has no depth to it at all, then I would think even people with larger sized arms should be able to reach the USB ports.
With that said, mine isn't mounted so I'm speaking from zero experience.
Thanks to both of you. I found them and will see how they work.
Found this on Vizio...
I wish they provided a little more flexibility or control over what the remote can do.
