AVS › AVS Forum › Video Components › Home Theater Computers › Will this remote work with MPC-HC?
post #1 of 5
I'm looking for a remote that will work with Windows Media Center 7 and MPC-HC. I recently made the mistake of purchasing this remote: http://www.amazon.com/gp/product/B00...ef=oss_product Quoting from one of the Amazon reviews, "This remote is not truly a "remote"; It simulates keyboard presses instead, which means that an advanced remote config program such as EventGhost cannot be used as it does not identify almost all of the buttons on the remote. This is dissapointing because It cannot be remapped to work for a custom program."
So now I'm thinking of getting this remote: http://www.newegg.com/Product/Produc...82E16880121003 Does anyone have experience with this remote? Is it truly a remote, or does it just simulate keyboard presses, like my current remote? If this remote is really a remote, then I should be able to reassign what the buttons do in MPC-HC.
post #2 of 5
That is a proper MCE remote. It should be compatible with EventGhost.
Why not just get a MCE receiver (HP Media Center IR Receiver from eBay) and a universal remote?
post #3 of 5
Thanks for the quick reply bryansj! Let me clarify my post. I don't want to use EventGhost or Melloware's Intelliremote program. I want to just follow GreenEyez' HTPC Software Guide for Windows 7 Media Center. All I need to do is go into MPC-HC. Then go to view, options, Keys, and then assign each Command to an "App Command." For instance, I will assign Next Subtitle to MCE_Yellow. Another words, I'll be able to use the yellow button on my remote to switch between subtitles.
I don't want to use a universal remote because they are expensive and I don't mind using multiple remotes.
post #4 of 5
Then the newegg remote will work with GreenEyez's guide. It will also work with EventGhost if you feel the need to expand its capabilities in the future.
post #5 of 5
Thanks for your help bryansj. I'll be purchasing the newegg remote.
