Originally Posted by dantaipan
I'd really like to listen to audio from my AppleTV2 in Zone 2. From what I understand you can't stream external digital sources to Zone 2. Is there any way around this? I guess the main reason I'd like to do this is the easy to use interface into itunes from the Apple Remote app.
I see oRemote is adding an "AirPlay" option in a coming release which appears to be a source selection. Will this be enabled for the 708 or just newer models? If it is enabled will it be able to output to Zone 2?
EDIT rworne clarified the AirPlay functionality for me on the FB page which is essentially controlling a connected iOS device. Good to know.
If you want analog on Zone 2, I do not think an Apple TV 2 will work, since the outputs on that are HDMI and optical. I am not that familiar with the Airport Express, but I do believe that has analog outputs. So the airport express would need to be used for Zone 2 playback. For example:
1. Connect AP Express to the desired input, let's call it "PHONO" in this case.
2. Set the AppleTV/Airport Express input in oRemote's settings to "PHONO"
The AirPlay button appears in oRemote. If this is pressed, the AVR switches to the PHONO input.
3. Tap "Library" and select your songs.
4. Tap "Done" and your selection(s) start playing.
5. If not set, change the output to your AirPlay device.
The song info displays on oRemote like other streaming sources.
