Originally Posted by
kulims
Is it safe to say then that the problem is user related ?
I had the 3007 and that worked like it should, no connection problems at all.
On the same cable and same router i had two 708 units, and both failed to connect the "normal" way.
The only way they would connect was to leave it running in Network Control mode, then no problems.
But this setting is using power 24/7.........
So i can say its not related to the user as the 3007 worked ok.
I did read some comments form a "network specialist" and he is working with these kind of IT problems all day and he could not get his unit to work in the normal way also.
