This was announced December 2010 and hopefull has a March 2011 release (as of Feburary, it is in the firmware testing stage);
http://epvision.com/HDTVSTB/phdez1pre.htm
Frankly, I'd rather have that then a quick release of something "buggy" like the disappointing Brightview/Zinwell DVR.
Since there is a drastic lack of DVR's that aren't leased/rented by MSO's (feeding their pockets), this would be more of a welcome addition since it has both OTA and QAM capability unlike the original DVTPal that is only OTA or that Moxi that is only CATV (both now discontinued).
What I am asking anyone reading this (since you have at least some interest) is to add their name to the inquiry with a valid e-mail address (it can be a secondary address) for the explicit purpose of drumming up interest in this product. No, I don't work for them, or in any way connected to them.
The only way this company will bring this to market is if they have a market for it and the only way for that to happen is people contacting the company, either by this inquiry or preferably a phone call.
Below is the reply I received when I inquired. Most has to do with their new tuner/switcher (which I didn't inquire about), but mention was made of this ez1;
This is my response;
One point I forgot to add is a program guide. A bad omission on my part.
Hi Bruce,
Thanks for the email. For your answer, PHD-eZ1 does have OTA and CATV recording features. Not like some PVRs can be only limited to OTA. We may end up to build full feature PVR instead of eZ1, reason is the cost is very close. We can add additional component and cvbs inputs and encoding but it will cost much more. Output so far is limited to HDMI and CVBS outputs just like PHD-8VX but we may change it the last min. based on the demand and cost.
For PHD-8VX, it is on the way to here. We will send out the re-release coupon this week or early next week. Please kindly find the attached PHD-8VX user manual for your reference. There are so many fine features added in this model and we are very excited about it. For some of the nice features mentioned in the following:
(1) Excellent 1080p scaling and enhancement. Video looks much richer than PHD-205.
(2) "Custom Aspect Ratio" adjustment so user can control video over-scan issue and cover 100% HD picture content on the screen. Not like many TVs chop out certain video content around the edges. This custom aspect ratio adjustment can also apply to PHD-8VX internal graphics as well as PC input video.
(3) Dual scan channel database. Keep both OTA and cable (QAM/NTSC) channel information and easy to toggle to each other.
(4) Additive channel adding: To periodically scan any additional channels without erasing the original channels and only adding them on top of it.
(5) individual picture adjustment on each inputs. We add brightness, contrast, sharpness and others picture adjustments for video. Each input adjustment is individual.
(6) Adding virtual surround sounds and other audio adjustments.
(7) USB port to play pictures as well as music (MP3) separately or both in the same time.
(8) Can accept PC inputs from both VGA/audio port as well as any one of 3x HDMI ports.
(9) PHD-8VX HDMI input can handle 24p mode to display even more vivid movie pictures if the source content is filmed by 24Hz from Blu-ray.
(10) New generation RF tuner reception. In some areas, PHD-8VX can pick up more OTA as well as QAM/NTSC channels!
So many more from PHD-8VX box...
Allen
ePVision.com
Hi Bruce,
Allen
ePVision.com
Allen,
Thanks for the reply. I was just interested in the DVR. As I stated, the most important features that are lacking are;
1. A second RF input (one for CATV, one for OTA),
2. A CC (Cable Card) slot to make it functional with all encrypted channels. Many cable systems are encrypting ALL channels, even 'basic' ones, so without a CC slot, the QAM tuner is pretty much worthless,
3. You say this will have a composite output, but no component? Component is necessary as some older monitors might not have HDMI and you should consider the fact all HDMI inputs on a TV might already be in use.
I understand these will cost more, but I'm sure most will gladly pay for what I consider 'basic' features. There is a demand for this, it's only because of the lack of consumer education the demand isn't greater. I would suggest going the deluxe route first. Don't come out with a limited function model, I don't think it will sell anywhere as much.
Thank you,
Bruce
Allen,
Thank you,
Bruce
