AzAssassin, Check out Wajo's sticky thread about our Maggy/Philips dvdr's in the "GENERAL" section under " HDTV PASSTHRU & ASPECT RATIO",there you will find links to the APPLE TV CONVERTER $149.00 and the AMBREY converter $209.00. Or you can check out this link:www.shinybowusa.com this is a new converter that is supposed to be released on 9/21/10,no price listed yet. There is also another converter made by a co. called ATLONA but i don't have any other info about it. I'm waiting on the SHINYBOW converter myself cuz they offer a 3YR. PARTS & LABOR WARRANTY. As far as i know,no other maker of these converters has as good a warranty as SHINYBOW. I don't know how well any of these converters will work,but i would strongly advise you to stay away from the LENKENG converter even tho it's cheap,cuz you may not like the result,and your $$ will have been wasted, and you may not be able to get your $$ back.I couldn't,and they carry no warranty at all,so if it doesn't work YOUR STUCK with it!!
G.
PS:I was wrong about you needing an HDFURY3, you don't need one.I had just gotten out of bed,and i wasn't thinking clearly.
G.
G.PS:I was wrong about you needing an HDFURY3, you don't need one.I had just gotten out of bed,and i wasn't thinking clearly.
G.
I also checked the Monoprice converter and i "think" it's the Lenkeng. I wonder, if you buy it and have less than satisfactory results,would you be any more likely to get your $$ back from Monoprice than w/other sellers? G.
