I posted this on the high end forum and the DIY, but this is probably best place and no responded on diy threads.
My client has old runco 3-tube to be replaced by digital projector but has a screen size space restriction. Existing tab rensioned motorized roll-down 9' x 5' screen is in a ceiling box roughly 124" wide. I want to give scope screen with masking for 16x9 and anamorphic lens.
Limitation of ceiling box has roughly 115" x 49" 2.35 screen w/ non-tab tensioned about the biggest we can go (maybe can squeeze a few more inches.) That makes 87" x 49" screen for hdtv. So movie (scope) watching increases by 7" width but hdtv decreases by 21"!
Would you change screens and use anamorphic like I suggest? (I would! prioritizing movies.) Would you buy fabric and masking panels and have a window treatment guy (my neighbor) help put fabric on standard window motorized rollers to maximize width and get the masking as close as possible to the screen surface? Which companies sell screen fabric (and masking panels) for rollers without it already part of a system?
Opinions? Thanks
Randy
Opinions? Thanks
Randy
