AVS › AVS Forum › Audio › Audio theory, Setup and Chat › The "Official" xtz Room Analyzer Thread
post #1 of 291
xtz Room Analyzer is a room acoustics measurement system and parametric EQ optimizer. The kit contains a microphone, a base unit with USB connection, and all the cables required to connect to a USB-enabled PC, and to the user's audio system. The software is downloaded from the website and installed on the users' PC, (Windows XP/Vista/Win7.) The system can also run on a Mac under Fusion or Bootcamp.
The system can measure:
1-position Frequency Response, (16 to 250 Hz)
3-position, averaged and weighted Frequency Response (16 to 250 Hz)
2D and 3D Time Frequency Level Charts
1/3 Octave RTA (20 Hz to 20 kHz)
3D Waterfall Charts
RT-60 Reverbation Time
The system can also be used to set filters on a parametric equalizer. The system will measure and analyze the room modes and recommend filters to offset the modes.
The manual can be found here:
http://www.xtz.se/custom/database/fi...0095834-01.pdf
The most recent version of the software is 2.0, build date June, 2009. Software updates, when they become available, will be posted here:
http://www.xtz.se/uk/support/file-archives
There are some special considerations when using xtz RA with Windows Vista. Please see the following .pdf file for more information:
http://www.xtz.se/public/file.php?RE...10452_1_12.pdf
Here are some sample images of xtz Room Analyzer, single position, Frequency Response in the main window and Time Frequency Level in the small window, upper left:
Here is a sample of the RTA display:
Here is a sample of the 3D waterfall graph:
The following are links to reviews of xtz Room Analyzer by Kal Rubinson in Stereophile Magazine:
http://www.stereophile.com/musicinth...tr/index1.html
http://www.stereophile.com/musicinth...39/index1.html
post #2 of 291
reserved
post #3 of 291
Boy, that was fast
Great job
post #4 of 291
lol, sure was... i just finished posting in the other thread that he should fire it up...
this is gonna be a lot of fun...
post #5 of 291
Great job in starting this thread.
Question on the room analyzer software, the most detailed graph view is with 6 ppo smoothing right? Is 6 ppo smoothing the same as 1/6 octave smoothing?
Also when measuring the sub (from say the main listening position), is the mic pointed up or pointed at the sub?
post #6 of 291
PPO is "Parts Per Octave". So yes, 6 ppo is the same as 1/6th octave smoothing.
Bass is non-directional, so the microphone can be placed straight up for measuring bass frequencies with the Room Analyzer. However, for measuring Full Range signals of speakers, (RTA, RT-60, 3D Waterfall), the microphone should be pointed at the speaker. The manual states:
"When measuring the full frequency span, the
microphone should be pointed towards the speaker.
(The microphone is sensitive of directions over 5kHz)"
Craig
post #7 of 291
Thanks Craig.
I also notice that the XTZ software does a level check before taking measurements; i.e. if I turn up the volume slider in XTZ the first sweep tone will abruptly cut off. Does this happen to you all also?
If so, any idea what is the cut off point? I was trying to push the level high to see where was the limit of my sub but it seems XTZ will cut off.
post #8 of 291
Thanks Craig.
Excellent questions. Unfortunately, I don't have answers. In fact, I am somewhat mystified by the level setting process myself. I don't know how to set a specific level for the test tone. The manual tells you to set the slider in the middle of the range, then adjust the system volume to get the level meter to the green "G".
OK, but what level is that? Couldn't there be an SPL readout? More importantly, what do the SPL numbers in the Y-axis of the FR graph mean?
It would appear that the SPL being measured is about 55 dB. Yet, when I hold an SPL meter next to the microphone during the chirps, I read about 82 dB. This is with the Master Volume Control at -10 WRT Reference Level at 0. Why are the SPL's in the graph so far off from the actual SPL's?
Also, if I use the slider to increase the level, I get the same issue that jchong described, with the system abruptly aborting the chirp and resetting the level on it's own.
In another section, under the RT-60 measurements, the manual states that you need a 100 dB level to take accurate RT-60 measurements. (Background levels in most rooms is about 40 dB, so 40 + 60 = 100 dB.) With my system at MVC 0, I read 92 dB on my SPL meter. Do I need to turn the system up to +8? And with an SPL of 92, why do the graphs read less than 70 dB on the Y-axis?
Hopefully someone from xtz will shed some light on this. I had e-mailed xtz support when I posted this thread and Jens replied that they would look in and offer help if they could. I hope they will.
Craig
post #9 of 291
All excellent questions that you have raised. I'm curious too and hope that Jens will chime in.
post #10 of 291
Because those numbers are the output for the individual frequencies (smoothed) while the SLM is integrating all the signal across time.
See above.
post #11 of 291
See above.
Kal,
First, just to be clear, your acronym "SLM", are you referring to a "Sound Level Meter"? Are you referring to the same thing I'm referring to when I use the acronym, "SPL meter", or "Sound Pressure Level" meter? I've just never seen it called an SLM before.
Assuming we are referring to the same device, then I don't understand your reply. These are "chirps", or sine wave sweeps, not noise signals. What would the SPL meter need to "integrate across time" with a sweep? If I hold my SPL meter right next to the xtz mic during the FR sweep, it reads 82 +/- 1 or 2 dB during the entire sweep, (SPL meter set up for C-weighting/Slow Response.) IOW, it (the SPL meter) is reading the SPL of each frequency, not summing the entire signal of a "noise" signal. OTOH, the resultant xtz FR graph shows an SPL of 55 +/- 3 dB, or about a 24 to 27 dB difference. That is a HUGE difference.
If the SPL of the sweep is read by my SPL meter as 82 +/- 2 dB, why does the xtz graph show each individual frequency of the sweep at 55 +/- 3 dB? To my mind, these SPL's should match within the calibrations of the individual devices. Certainly they can't be mis-calibrated by 24 to 27 dB.
Craig
post #12 of 291
Kal,
Yes.
XTZ is gating/analysing the sweep in order to distinguish and display the output at the different frequencies. The SLM cannot measure an instantaneous frequency in the sweep but has a time window ("Slow Response") over which it measures everything in its capability. So, let's say you play only two tones of 55dB so quickly in sequence that the time constant of the SLM prevents them from being distinguished, it would display 58dB.
post #13 of 291
Thanks again CG for starting the thread.
I have a novice question on how to read the RT60 graph. Can someone point me in the direction of a primer on how to interpret that that is telling me?
post #14 of 291
2 questions for you users
Can it measure resonances/decay times in the 500-1000 hz region? I've only seen screenshots for <250 Hz
Is there any online source for the kit in the US or do you have to buy it & have shipped from overseas?
I would like something like this to use and don't want to steep learning curve or have to pay $400 for a mic/sound card kit (like with ETF)
post #15 of 291
Yes, I would love to know where I can order this. I live in Canada, and can't seem to find a place that will do it.
post #16 of 291
http://www.xtz.se/uk/about-xtz/our-retailers
International orders (from countries other than the ones listed above)
You can order by sending an email to: info@xtz.se
Please state your:
* name
* address
* country
* phone number
* and the prodicts you wish to purchase
We will email you the total cost (including shipping) and explain how payment is made.
post #17 of 291
It can display decays across the entire 20-20k bandwidth but the output is only graphic, not numeric (except for RT60), and at lower resolution than for LF only.See pages 29-33 of manual (http://www.xtz.se/custom/database/fi...0095834-01.pdf).
Kal
post #18 of 291
Thanks, Kal!
post #19 of 291
You can just buy it online here: http://shop.xtz.se/Overview and they will charge you a flat rate for shipping and duties. With the exchange rates right now, it was a bargain. I wound up paying an extra 5 bucks in duties, but it was pretty painless.
post #20 of 291
Coo...thanks guys.
Just found another site that will ship it for £179.99 including shipping to Canada.
http://www.audiosanctum.co.uk/Access...r-Package.html
I hope this program is a good choice. I really am just learning all this stuff, and thought this might be the easiest way to get into it. Worst case scenario, if I can't figure it out then I'll just sell it I guess.
post #21 of 291
I ordered mine from the UK, from this place: http://www.audiosanctum.co.uk/vmchk/...r-Package.html
Worked out to be cheaper. Note: they deduct VAT for out of UK shipments.
post #22 of 291
I suppose one way to verify is to play test tones instead. Use the RTA function on XTZ and play some test tones say at 20Hz, 40Hz, 50Hz and 80Hz. Compare the RTA reading (at those frequencies) vs SPL meter.
Would that work?
post #23 of 291
Would that work?
It should, within the error boundaries of the two and assuming both are calibrated.
post #24 of 291
I'm confused about how to plug the RCA cable into my Onkyo 1007 AVR. I want to check out the response to my full audio system, after running the 8033 AntiMode followed by Audyssey. Do I use RCA cable coming out of the mike, and then the Y-cable and plug it into one of the 1007's stereo inputs (e.g., the VCR input)? Then I don't see any use for the two RCA connections coming out of the base. ?? TIA
post #25 of 291
Good thread--glad i found it. Just got my Kit last week, hope we can all learn to use this tool together.
I've played with it a bit, and the one thing i can't figure is why i keep getting a message that says "No nodes found"?
Perhaps because I'm running full range? And sometimes I do get a node. Anyway, looking forward to enjoying the XTZ.
post #26 of 291
OK, a friend helped get the SW downloaded; I'm a Mac guy, but have gotten 'Fusion' to run Windows XP within a shell on the Mac. It works!
I finally decided I didn't need the two RCA outputs on the base; simply the USB cable, that is attached to the mike frame, to the laptop, and the RCA line, attached to the base, connected to the long one to the AVR.
I was pleasantly surprised to find that my room is not bad w/o any eq to start with: no more that a 5 dB variation from min to max over the whole range. I then turn on the AntiMode 8033, and then run Audyssey. I also have a BFD 1024 lying around, I thought about using it to set the 1 or 2 filers the XTZ suggests, but finally decided it's more trouble than it's worth, e.g., having to get the level set so as not to clip, etc. (With WOTW I couldn't get the AVR low enough for the BFD not to clip!)
So I'm very pleased with the XTZ: it very fast, so one can run it many times, before and after all the possibilities, e.g., with or w/o the AntiMode and/or Audyssey, and also with the Sub arranged in different ways.
BTW, I find the my SubMersive gives best results sitting by the side of a couch, with one of the woofers pointing out into the room, and the other back at the wall, about 8-9 in from the wall.
post #27 of 291
How do you get the screen shots into a format where you can post your XTZ graphs?
post #28 of 291
You can either:
1) Use the "print screen" button to capture a screen shot
2) Within the XTZ software go to File --> Export Screen Dump. This will create a bmp of the screen
post #29 of 291
Cool, thanks.
That will help us all with this thread.
post #30 of 291
Are you sure you had the setting on the back of the BFD at -10dBv (pushed in for home) instead of +4dBv (pushed out for studio)?
