I am getting realy frustrated about the 3D mode.
From my understanding it should be 960*1080 pixels (per frame - when played back on 3D capable TV or projector it should fill the 16:9 fram with 1920*1080).
BUT - when i record in 3D i can see allready on the built in display that it does NOT fill out the screen all the way. It is not 4:3 and it is not 16:9 and it is not 960*1080 (which would correspond to about 1:1) it is something like a 12-13:9 format, cropped on the left and right side BUT also top and bottom?
The same thing when i look at the material in 3D on my JVC DLA-X30 (RS45 in US).
I have several motion pictures in 3D SBS and they DO fill out the screen entirey, of course they are actually only 960*1080 per frame, but the pictures is strectched to fill out the 1920*1080 pixels as it should.
Why the is the Panasonic HDC-SDT750 with lens attatchment VW-CLT1 not doing this the right way?
I can not find any info about this on the net and I can not find any FW updates on panasonics site.
Is my camera broken or does everybody suffer from this crappy non std format in 3D?
PLEASE help - i bought the camera primarily for 3D since I am just in love with the format (doesnt matter if picture is not as good but it MUST fill out the screen or you will loose a lot of "natural visual depth" unless you increase picture size but I can not do this only for a camcorder now can i)
See attatchement for what i mean with the cropping.
When shooting in 2D the red marked area is also utilized - same with final movie when played on projector.
Whats up with 3D? it is not 960*1080 at least
Regards
Boogieman
