Originally Posted by davyo
With the JVC,,, I would do BD and cable box directly to the JVC's two optical inputs, then the PS3 and and media player to the plasma and use the plasma's RCA out to the JVC's RCA in.
With all the connections you need to make you might want to look at one of the Sony CT-XXX's if you dont need the wireless sub.
While I do think the JVC is the better sounding of the two brands the Sony is also an exellent little system.
Cheers
Davyo
Cheers
Davyo
i have a similar setup to this - cable box, standalone bluray, and a PS3. i want the simplest setup possible, with the least amount of remote switching. given that Sony has a HDMI repeater, it would probably be better in terms of connecting all components and getting full sound. however, ive read from your review that the sony remote and menu system is cluttered. is JVC really the best bet? i would connect BR and Cable Box via optical to JVC, and use your suggestion to keep PS3 via hdmi to tv, and then use RCA to connect TV to JVC.
