ill try to keep it short ..sorry if i write too much...
-buy refurb 50 inch led tv for $1k from tiger and it comes with rainbow effect on all corners , lower left corner being super noticeable.
-return the tv and decide to actually stop being cheap and go to bestbuy
-buy the LN46C750 , for 2.3k (with ensurance), when i get home i noticed all four corners had a bright colorless strobe of light pointing to the middle of the screen.
-i return the tv and tell them i loved the model so id like to just exchange for the same model, but b4 i were to take it home id like for them to open it up and check to see if it has the same problem.
-they open 3 of the same kind, and they were at least 2-3 times worse than the one i took home. on the 4th tv they open, i didnt notice the problem.
-i get home i conect to pc and open photoshop to display a black picture on to the screen, thats when i realized why i hadn't seen the strobes at the store... it was because the ENTIRE screen was leaking light, kinda looked like clouds... anyways..
-return the tv, 2 weeks after i go to another bestbuy and i buy a UN46c6900vf for a lil more than 2.3k with ensurance (the person helping me this time told me the tv wasnt edge lit so there shouldnt be any problem, but he couldnt open the box because i hadnt payed for the item...)
-i get home i realized i payed $100 more for an older model than the one bought last, and doesnt even include 3D technology and it WAS in fact edge lit)
-turning it on i notice there isnt any fixed strobes of light, BUT, as soon as the image is dark and there is something bright ex: night sky and a bright moon in the center... the bottom part of the sreen in the same vertical direction where the bright item is lights up... so its not a fixed strobe but multiple strobes of light fire up to light the light objects in the middle of the screen.
--where playing a game like bioshock, or deadspace where the setting is darker than usual with few flames or monitors on screen lights up the entire lower part of the screen.
what i want to know from you guys is 2 things...
1. am i being too picky? Should I have settled for what i had got???
2. if answer to #1 is no then does anyone of you know of any models out there where i wont run into the same problem??
-im willing to go as far as to $2k (maybe just a lil bit more)
-image quality needs to be decent and even.
-3D is not a must
-pc connectivity IS a must
-will be using the tv mostly for Vgames/hq movies and specially as a monitor.
if you think you can help me please do.
and lastly thank you for taking your time to read all of this.
-3D is not a must
