I have an issue with my Panasonic PT-50LC13 RP LCD TV.
When you turn it on, it shuts off. Looking up the blink code in the service manual, the code means that FAN1, FAN2, or FAN3 is stopped. The TV eventually can be coaxed back on, however.
I opened the TV and took a quick look. Without pulling it apart (again, I've already had to fix the ballast), I can easily see that FAN3 & FAN4 are working. That just leaves FAN1 & FAN2. Both of those appear to be inside the Projection Unit.
The service manual says to replace the entire projection unit (LSXA0528-HBS). Those run $225+ just for a refurbished unit. To mean it seems stupid to replace the entire projection unit just for a <$20 fan!
Is there any sane reason I can't just replace the fan on the unit? I've never opened it up, so is there a concern for dust contamination or something? If it's possible to replace, does anybody happen to know the model #s of the fans inside the unit? I hate to tear it all apart to just get the #, put it all back while the parts get shipped, and then tear it all apart again.
