Nixeus have now released the latest Beta of the firmware for the Fusion HD.
Please report any comments/issues either here or at the Yahoo group.
Details of where it can be downloaded from can be found here..
http://tech.groups.yahoo.com/group/Nixeus_Fusion/files
Changelog:
Nixeus HD Firmware v01.11.12.17.37 Beta
This beta has been tested by Teddystacker and appears to work well.
Please post your comments/feedback at the Yahoo group or AVS thread.
1) Support added for "sort by date" - at this time, only single files are sorted by date - this is a VERY useful feature if you have a download directory with 100's of un-sorted files in it.It allows instant access to the most recent file.I know of no other media player that has this feature.
2) Support for "My Favorites" added this works on USB, HDD and network shares.At this time only single files are supported but hopefully Folder support will be added in a later firmware.To use this, browse to the file you want to bookmark using the file browser , then go to the options on the right hand pane , click on the star , and that file will be bookmarked.The go back to the main page and click on the Yellow star , you can then play your file directly from there.
3) Support BD ISO playback - BD-Lite Support now added ,it is hoped that this feature will again be added to in a later firmware.
4) Copy and delete feature from USB or HDD is now working again (see page 42 of the manual for full details).This was broken in the last beta firmware release.
5) Fixed date setting issue when first booting.
6) Fixed DVD menu not exiting correctly when USB removed.
7) Fixed DVD menu issue.
8) Fixed RSS "Value recording limit exceeded The following were not recorded" issue
9) Fixed YouTube homepage issue.
10) Better Twitter Support.
11) Rudimentary PAL TV System support - this is accessed via cycling through the "TV OUTPUT" options on the remote control , there is no option in the setup menu as yet , this will be added later.
