For those of you all using this player with a Mitsubishi DLP I have some questions questions:
1. If I go into settings and set it for checkerboard and then when I play a 3D BR it will be 3D, right?
2. Once I set checkerboard in the panny is it permenetly set until I change it?
3. What if I watch a 2D movie, how does this work? Does the panny know what is and isn't 3D or it is always putting video out as checkerboard? (not good for mitsubishi as resolution is less so obviously that would suck for 2d movies).
Basically I want to be able to set the settings in the panny to checkerboard but only have it out checkerboard when a 3D BR is being played and when I put in a 2D movie I want a non-checkerboard signal coming into my tv.
