AVS › AVS Forum › Audio › DIY Speakers and Subs › kornny's project
kornny's project
post #1 of 49
Hey, I figured I would just post the stuff here.
I'll send up a sim later, the original is really worthless. It's the final sim that counts. Once I get the cab down, I'll run a new sim based on the plans in AkAbak, and modify things a little.
I am close on the fold. Just a small adjustment to get both curves to touch the edge in the right side.
post #2 of 49
This looks like it may be the way to go, with a slightly taller cab. We'll see...
post #3 of 49
Does it need to be that form factor, ie is it designed to take into account truck packing or will it be used domestically? If the latter, taller and thinner with maybe a single fold might work better.
What are the performance specs?
post #4 of 49
Ok Do what you must
post #5 of 49
Using what for a driver(s)?
post #6 of 49
What driver and what is the length of the horn?
post #7 of 49
A9X-308 & Penn,
The form factor is set. ~ 60"h x 45"d x 25"w. It is a 20Hz horn with a horn path of over 18ft.
The goal was maximum output to 20Hz 1/2 space at that form factor, with a little wiggle room. These will not be moved around, so portability is out. With the 4pack planned, 145-148dB should be achievable at 20Hz in 2pi.
The side goal was to outdo the previous folded horn design I folded for him. Pretty much the same goals there, only the driver was different, and it was only run to 30Hz. With the four pack getting a little lower.
http://www.diyaudio.com/forums/subwo...an-work-5.html
Fatawan,
It is using one B&C 21SW152 4ohm 21".
I do not want four 180deg corners if I can help it. With the next fold attempt I can get it down the three. I just need to tweak the horn path width some. If I could flip the H & D dimensions I could make the middle fold work no problem. It would be the best option, as the driver is in a compromised position as is.
post #8 of 49
Well those numbers are
Pretty Fng CRAZY
I still have a space (Built into my HT wall) that needs a horn that is around 24x24x48, obviously this wont fit
post #9 of 49
That's a big-un. Throw up the specs later. I want a gander at them. Someone is building 4 of these?
post #10 of 49
Looks like it will end up this way. Only two hard 180s, and still up close to the front.
post #11 of 49
Will we lose anything with this type of folding.
post #12 of 49
Anytime you put a bend in a horn you will alter the response. The key is to account for it.
It's going to be close, but it should pan out. I can account for the path length, but the acoustic resistance through the bends is a little tricky.
post #13 of 49
Ok, here is a demo of some things I am thinking about putting into the advanced AkAbak modeling series.
First of here is a simple TH model. I say simple in that it is what Hornresp or AkAbak will give you the normal way people are modeling them. This model contains ~40 sections, so it is pretty thorough. As you will see it still leaves a lot to be desired.
Ok, first up is the "normal" model at 28.3v.
Here is the Impedance
Finally, the Xmax Graph with both drivers.
Pretty normal stuff, right?
Now will will add in the additional acoustic resistance the bends can add at these higher SPL levels.
Here is the same horn will the bends close to the start of the same horn at the same voltage in.
FR
Imp
Xmax
Notice the xmax drop, and think about what this means.
Here are the FR graphs with the bends more in the middle, and then at the end with the tap.
post #14 of 49
This would explain why the peaks and dips in FR that HornResp predicts are tamed in the real world then correct?
post #15 of 49
what happened to my reply? i suppose it got lost in cyberspace...
i was curious to know why the switch to the b&c from the ciare driver that was in the link.
second question is the frequency response doesn't appear to be a tapped horn. more of a sealed/front loaded horn. which is the latest proposed design?
third question is will this be going in a home theater or an imax? if home theater, it would seem a poor choose of extension vs. sensitivity. i love dynamics as much as the next guy, but 145db in a home environment is simply not necessary.
post #16 of 49
Yes, it can explain it. There is also more there too.
This isn't a switch. This is another set of four subs. The Ciare OD horns should be nearing the building phase in just a bit.
I'm not sure which FR your are referring too. The stuff in the link all pertains to the Ciare OD horn. The FR graphs I have posted here are from another "real" TH.
Nope, this is not for a HT. Kornny has been very adamant about extension, so that is what he is getting. Four 40Hz horns of this size could have been playing in the 150s, but that was not wanted or needed.
As far as extension vs. sensitivity I do not follow. What do you think the sensitivity on these are individually? The TH is still up in the air, but the Ciare is in the triple digits.
post #17 of 49
I like but 21 inch driver too big
post #18 of 49
Kornny when you burn these drivers up you can use them as rims
post #19 of 49
To big for what?
post #20 of 49
My plan is to build 4 TH with the b&c and 4 Folded horn with the ciare.
post #21 of 49
what is the implementation, i.e. where, how, and for what purpose will these godzillas be used?
post #22 of 49
[quote=LTD02;18989612]what is the implementation, i.e. where, how, and for what purpose will these godzillas be used?[
The subs will be use out door in open area for different events.
post #23 of 49
ahh, that makes more sense now. somewhere along the line, it was mentioned that these would not need to be moved, so i assumed a fixed install. i just couldn't see the point in 4 of these for a fixed install. four in an outdoor application where high spl and full range are desired makes sense. sorry if my comments came off the wrong way. i was legitimely confused.
post #24 of 49
what kind of events do you run? if you are close, i might drop by just to hear these godzillas.
post #25 of 49
I will be building a set in the caribbean and a set in ny bkyln.
My next goal is to design a good full range to go with these subs
post #26 of 49
I just had a weird dream that four of my monsters brought earthquake to the City. I love this love.
post #27 of 49
So we final finish building and installing the Ciare 18 folded horn for tomorrow.
Ohso genius thanks a million those box sound good+10 ,the bass coming from 6 of them is crazy deep. i was blown away. cant wait for you to finish that 21" sub for me.
post #28 of 49
You went with 6!
Pics!
post #29 of 49
sorry no pic,i will try tomorrow if i get a chance.
6 of them on on truck nice.
post #30 of 49
so any update on the 21 sub
I am in the mood for a deeper bass
