Originally Posted by
Frohlich
I make the original Tibetan midget crack and his response gets all the Kudos?? Fine...I am taking my soccer ball and playing in my yard..I don't need you guys
crybaby...
ok, ok, the original crack was good too... i was off having myself a hissy fit when you posted it, so i didn't respond...
hifichip76
ok. I've been reading more of this thread, and thanks for the reply.
So, it won't accepot dsd via HDMI, but it accepts SACD over HDMI if it's already been converted to PCM. AND you guys seem to feel that it's no loss and sounds just as good, right?
So now I have to find out if the Sony 5400ES will transcode it to pcm itself...hmm.
Denon's 4311 AVR (and I think similarly-priced avr's from Pioneer Elite and Marantz, but not sure) will decode DSD. I don't understand why a pre/pro would not have it, as some of you have said..
yes, it sounds "just as good"... as long as the dsd decoder isn't broken, it doesn't matter where it's done...
likely because it's not really "necessary" in the grand scheme of things... i've never had a player that DIDN'T decode dsd to pcm... not saying there isn't one... but i've never come across one... edit: i guess that sony likes to prove me wrong...
unless a component has a direct dsd to analog dac (which isn't overly common), the datastream is always going to get converted to pcm anyway...
