AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz AV7005
Marantz AV7005 - Page 55
post #1621 of 9375
no, it will not accept dsd...
the recent conversation has primarily centered around that...
post #1622 of 9375
Originally Posted by Smackrabbit View Post
When then 5400 sends multichannel PCM to the AV7005, it's at a bitrate of 24/176.4, and it sounds fantastic.
we gonna see a review from you soon chris?
Originally Posted by msilverz View Post
Can you turn on Audyssey when the AV7005 is receiving multichannel PCM at that bitrate?
Matty
yes, inquiring minds want to know....
post #1623 of 9375
Thanks. Not a deal breaker for me but unfortunate nonetheless. Based on the reviews here it sounds like the AV7005 surpasses the SR8000 series performance wise. I was going to upgrade to the SR8002 but I may as well get the AV7005 for a few hundred more. I don't need the networking features and HDMI upgrade yet but I may want them later.
post #1624 of 9375
How do you get AV7005 to display bitrate
post #1625 of 9375
@dbelon...
won't comment on "sq", but feature wise, yup, the av7005 is a superior unit to the av8002...
i'm rather fond of mine... worked "out of the box", nice feature set, no quirks (other than the volume control that accelerates like the super snake, which appears to be a d&m "feature"), looks nice in the rack...
not really sure how many are actually out there in the wild, but we haven't come across any real "show stopping" issues... that may change as more people get them in their hands... that being said, at least a few of us have exercised them pretty thoroughly... i think we've got a pretty reasonable "handle" on it now, and should have it completely deconstructed relatively soon (hopefully to the point that "we" deconstructed the pioneer sc series avrs)...
imo, ymmv, etc.
post #1626 of 9375
it will show on the display that is hiding underneath the front panel if you press the "status" button...
post #1627 of 9375
Originally Posted by eric9h View Post
Thanks for pointing me to that page. Did the reset, didn't work. Guess it's going back...
darn... it was worth a shot...
before you send it back, try dropping a quick question in the audyssey thread... it's possible there's something that i'm "missing", i'm much more familiar with mcacc than i am with audyssey...
post #1628 of 9375
Over the last two nights I have watched "Sherlock Holmes" and "Terminator Salvations" through mine and I have to say I am getting more and more impressed, particularily Terminator it just sounded awesome, increadible dynamics and detail.
Could not be more pleased
post #1629 of 9375
In regards to not accepting DSD: If the transfer rate from the source is high, and the signal needs to be converted to mpcm in order for the Audyssey to be included in the process anyway, it's a non-issue for me personally.
post #1630 of 9375
i'm glad they reviewed it, but if that's the type of reviews that we are now going to get from ah, that's REALLY disappointing... at the VERY least, the reviewer should understand the concept of channel trims...
amoungst other things... such as zero test results... and so on...
at least it was positive though...
Just a little FYI.....
That was a personal review of the product from a guy who recently joined AH and after he posted that review, Gene seemed to really like his review and it I believe they tweaked it a bit and posted it like they did...
You can see his original over here... http://forums.audioholics.com/forums...ad.php?t=69654
I thought it was a nice personal review, but I agree not of the caliber of what an AH full review should consist of, but hey, I don't run the site thats someone elses baby....
post #1631 of 9375
thanks. wish there was a way to show on screen as my gear is 18' away from my couch and 9' off the floor.
post #1632 of 9375
Matty
Unfortunately I'm packing up to move right now and all my SACD's went into a box this week. I will see if I can find something to test with.
post #1633 of 9375
I'm working on the review now but also packing up to move cross-country so probably mid to late January but we will see.
post #1634 of 9375
Is the AV7005 using the same Cirrus Logic 8-channel DACs used in the AV8003?
post #1635 of 9375
The "Information" menu provides that info, if you don't mind pulling up the setup menu. Also, that menu is available via the web interface if you have it connected to your network.
post #1636 of 9375
Well, the AV7005 does not turn Audyssey off with 24/176.4 PCM as it does with a dts MA 24/192 bitstream.
post #1637 of 9375
we have white smoke coming from the tower!
thanks kal... edit: i'm assuming we'll see a review from you sooner or later?
post #1638 of 9375
Time to buy that SCD-XA5400ES folks!
My DTS disks are all 24/96 anyway, so not an issue here
Thanks Kal!
post #1639 of 9375
On it now. Probably March issue.
post #1640 of 9375
Kal, will the av7005 apply Audyssey if it receives 24/192 pcm as well? I was under the impression that it lacked the processing power to apply Audyssey to anything(pcm or bitstream) greater than 24/96?
post #1641 of 9375
That point was made in the context of bitstreamed HD codecs which require the Marantz to convert them, thereby using some of the DSP power for that. I cannot answer your question at the moment but I will find out.
EDIT: Yup. 5.1 24/192kHz PCM from the 2L Nordic Sound sampler works fine with Audyssey.
post #1642 of 9375
No. The AV8003 uses the Cirrus CS4382A, while the AV7005 reportedly uses the AKM AK4358. Marantz seemingly preferred Cirrus DACs in its AVRs & disc players until the shift this year to a common platform w/ Denon. All Denon xx11CI AVRs (including the 3311CI on which the AV7005 is based) use the AK4358 in single or dual differential configuration (4311CI).
Both the CS4382A & AK4358 are monolithic eight channel DACs. Both have similar dynamic range specs, though the CS4382A has slightly better THD specs. And both accept DSD input, but Marantz has opted not to support DSD in the AV7005 (probably because the HDMI receiver or the DSP does not pass DSD).
AJ
post #1643 of 9375
Thanks a bunch Kal.
post #1644 of 9375
The Marantz manual indicates that the AV7005 cannot apply any Audyssey post processing to "HD Audio" w/ a sampling frequency >96 kHz. But "HD Audio" is vague terminology. Does that mean bitstreamed lossless codecs, LPCM, or both? Kal resolves that issue. The "HD Audio" limitation applies only to bitstreamed lossless codecs.
AJ
post #1645 of 9375
Hi All
I finished my rack today and thought I would show you some pictures with the AV7005 and Oppo 93.
post #1646 of 9375
Nice integration, job well done. Congtats!
I will also post some pics once the Fedex guy delivers my new toys
post #1647 of 9375
Originally Posted by Ed Van Belkom View Post
Hi All
Wow, that really does look good, great job there.
post #1648 of 9375
yo ed, nice rack!
what are you using in there? one of these days, i need to build me something in like that....
post #1649 of 9375
Hi All
Excellent work. I wish I could do something near that good.
post #1650 of 9375
It's worse than that. The "review" completely contradicts itself in places.
For example, in the summary of "pros", it says: "Packs a billion features: a true feature creature!"
Yet, in the second sentence of the "review" he says "It doesn’t quite go the extra mile in terms of features..."
Uh, ok.
