Originally Posted by m. zillch
Something I've never understood with the "transistors need to be burned in" crowd is for some unknown reason:
A) Once the magic period had passed (40 hrs, 80hrs, whatever) the new sound they claim is always superior and never inferior (and only very rarely "equal"). You never hear, for example, "I loved the sound of my preamp when new, but then after it was burned in I noticed a loss in the highs and lack of authority in the low end after 80 hrs of use."
B) Similarly, once the magic burn in period had passed the new sound is then "fixed and unchanging". You never hear, "After burning in my preamp it sounded great the first half year, but then I noticed a gradual loss in the high end shimmer by the year's end."
Weird how the change in sound is always positive, never detrimental, and also weird how after burn in it becomes "fixed" and stagnate. If modern day, solid state audio electronics indeed changed audibly, based on the number of hours of use [which they don't], I'd think the change would be continuous. But heck, it's their mythology so they can make up the story however they please.
yup. i too want to know how this can occur. i told a poster in another thread today to apply "reasonable man law" when someone tells them something. applying "reasonable man law" to the subject at hand, it's very easy to be skeptical about "reported results"...
yup. which in all likelihood, is exactly the way the previous piece sounded (assuming processing turned off, etc.)...
i'm gonna need a lot of spoon feeding to not fubar the setup...
