AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz AV7005
Marantz AV7005 - Page 161
post #4801 of 9386
Thanks ccoten,
What if all I have at the house is wireless, and my work I have a Ethernet cable do I still hook up before checking??
post #4802 of 9386
Originally Posted by punt5656 View Post
My AV 7005 came in today! Before I hook everything up I wanted to make sure that I have the latest firmware. I called Marantz earlier to ask if i could do this without having it hooked up to a monitor and they said yes. So I hooked my Ethernet up and turned the AV on and pushed the menu botton as the tech told me to and nothing happended??? The tech stated that it would be displayed, and that i could go into the Manual set-up, then option set-up. I couldnt ever get the Av to display this or the remote. Can somebody help me on this one?
Thanx
your av7005 came in...lucky!!!
ordered mine last week...dealer says may be the end of the month 'til it arrives, and that's subject to change
post #4803 of 9386
Originally Posted by m. zillch View Post
Be sure to send the remote in as well, of course. It might have a partial short.
You might also try a master reset before sending it in, just for yucks.
I am going to do a master reset tomorrow. It started locking up tonight while I was writing down my settings in the menu. Then I kept watch TV for about 10 mins and it started working again(I had it in SAT before entering menu)
If that doesn't correct the problem, I might try a different remote before sending it in.
post #4804 of 9386
where can I find the latest firmware for the AV7005? Mine is supposed to be here in one day. How do I check which firmware I have>?
Thanks in advance.
post #4805 of 9386
Thanks in advance.
You can't. It doesn't seem to be published anywhere.
To check which firmware you have, you connect to the web and check for up-dates. It will tell you if an up-date is available. If there is new firmware available, Marantz doesn't tell you what has been changed.
I thought you sold yours?
post #4806 of 9386
So this must be done while contacted to some kind of monitor. My problem is that i dont have a land line at the house, all I have is wireless. The tech yesterday told me that i could do this without hooking it up, which i find to be false
post #4807 of 9386
i have 2
post #4808 of 9386
i have 2
Stereo?
post #4809 of 9386
Please clarify. Is your wireless for a laptop and if so you can plug into the wireless router.
post #4810 of 9386
I've had my AV7005 for about 3 weeks now and am still on the steep part of the learning curve due to limited time. (taking an EMT course so free time is at a premium). When I first powered it on (hard wired to my router) It informed me that there was a firmware upgrade available. I then selected the option to install it.
post #4811 of 9386
Yes wireless to my laptop, tech support also told me NOT to plug into a wireless router. I have no idea why??
post #4812 of 9386
Sure you can update without a screen connected and you can also do it via wireless lan. Just navigate your way through the menus.
Due to poor reception in my concrete basement my AV7005 is connected to a Bufallo wireless client which connects to a wireless repeater which then connects to my wireless router.
Done 3 updates this way. No problems so far. Also worked for 3 years with my Denon 3808a without any glitch.
post #4813 of 9386
Nevermind; it's updating right now, I got so excited that I didn't even bother to open the front panel to look at the lcd screen to navigate myself thru for updates. All is good
post #4814 of 9386
FYI: My Middle Atlantic rackshelf for the AV8003 did nto fit the AV7005. The feet on the AV8003 hod it up about 1/8"+ higher so the units body can't stick through the hole . No way evident to adjust that or make it work. If anyone else did, let me know, please.
Edit: called MA. They verified it is a different part. Ordered a replacement faceplate only.
post #4815 of 9386
GetGray
Have you been able to compare the sound quality of the 7005 to the 8003?
post #4816 of 9386
Not really. Just swapped them last night. Haven't had time to even reprogram my control system. Be a while.
post #4817 of 9386
I just committed to buying the AV7005 sitting in classifieds. Did anyone else see that one for $900?? I couldn't click fast enough!
Can not wait to try this pre/pro out!!!
post #4818 of 9386
about time you joined us... it's not like you to wait so long for something you want so bad...
yes, i saw it... i'm glad someone jumped on it fast, as i was hoping to get a bit more than that for mine if i do sell it...
post #4819 of 9386
I was waiting for the "deal"
Now I have to spend maybe $4K on a new 3D projector
post #4820 of 9386
well, you certainly got one... $900 is a steal...
shhhhh... don't say the "p" word... i am trying VERY hard to not buy one right now...
post #4821 of 9386
So the new prepro actually cost you $4900? What a deal. lol
post #4822 of 9386
lol, its going to since I do want 3D.....
post #4823 of 9386
Mine will arrive from the AVS store Friday. I got a really good price and they have a few left in-stock.
post #4824 of 9386
Originally Posted by ccotenj View Post
because i'm a hardware whore........the av7005 is a wonderful piece...
just curious, you still got your AV7005 in your system?
post #4825 of 9386
go a few pages back.......i covered it all. the new AV7005 fits GREAT!!!!
post #4826 of 9386
There is a rack mount kit for the AV7005 or the 8003
P/N Marantz RMK8003AV
I have one on order with the AV7005 coming from AV Science.
Kevin
post #4827 of 9386
yup... want to see who comes out with what and let it hit the street and get sorted out... there's a grand total of zero "new for 2011" features that have usefulness to me (or that i lust for, regardless of usefulness, ftm )...
so while i have wandering eyes right now, i don't think there's anything arriving in the near future...
my object of affection right now is a xt32 avr/pre-pro or a as-eq1... and i can wait on that to see what develops...
post #4828 of 9386
Sorry Scott, I may have given you bad information in an earlier post. I looked at mine again. Middle Atlantic sent me a faceplate marked SR7005 for the AV7005. I believe I told you the AV8003 fit.
post #4829 of 9386
Just finished hooking the Av7005 up, it's amazing! A little confusing at first, I still don't know if I manually programed everything correctly but it sure does sound nice! Alot of features that my HK didn't have.
post #4830 of 9386
Deleted
