Originally Posted by Whacked!
Sorry, but I find both of these comments would require quite a bit of extra hardware to implement as discussed.
MZ, you could consider the tape outs for use in an HT bypass but there are better ways as this likely wouldn't give you the surround processing you're looking for (might be pre-pro feature dependant).
Nathan, you wouldn't need additional amps, that kind of defeats the purpose of having a 2 ch pre that has a HT bypass input.
Basically, if you have a 2 ch pre that has HT bypass capability, it will have an input that can be used as a "Unity Gain" input. Using this input would pass the audio signal through unaltered, bypassing the 2 ch pre's volume control and any other settings that might normally be used for 2 ch. The 2 ch pre normally needs to be on with this input selected for use with HT. Your 2 ch listening source is connected to the 2 ch pre as are your amps and speakers, your pre-pro is not used for 2ch listening.
The front left and right pre-outs of your pre-pro (or AV7005) feed to the unity gain input on the 2 ch pre. When doing HT, all your pre-pro processing is applied to the output signals as if the 2 ch pre was not installed. Your volume control also works and there is no need to adjust the volume on the 2 ch pre to compensate for it's effect due to its unity gain feature/function.
The only extra hardware in this scenario is one set of interconnects and your HT bypass capable pre amp.
Hope this helps. Norm
yeah, you are completely correct. i don't know what i was drinking this morning, but maybe someone gave me decaf!
And I really didn't want to invest in a Denon player, being very happy with Oppo universal players. So I started a
