Just to be sure you realize, there could be a lot of pitfalls to getting it, assuming you also plan to use it here in the US:
-No warranty coverage through US dealers
-may not be expecting US AC electricity
-may not search for firmware updates or if it does it may be searching for them to a different server on another continent which refuses to download to a US location
-no Airplay upgrade , possibly
-FM tuner radio deemphasis might be off
-RF tuner antenna connection might be odd (smooth, push on F-connection with no threads, for example)
-may not have "HD radio" at all
-may not be expecting NTSC signals (PAL SECAM etc)
Yes, there may be ways around these things, but I'm just sayin.
That's exorbitant (if one is concerned only with shielding, sound quality, and durability, that is. If pretty colors are your thing, I can't argue with that.)
