Originally Posted by pwz414
I'm noticing high frequency effects just sound like noise. Beads clicking and bugs in "Avatar" are just noisy, indiscriminate sounds, but they are loud and distracting. I also noticed a raspy distortion in the Tri-Pod's horn during the emergence scene of "War of the Worlds"... It is much more apparent through my center channel than phantom. A lot of the high frequency stuff almost sounds like it is distorting, resulting in the noisy lack of detail. It's really irritating. From all channels, BTW.
I never noticed this with the NAD. Is it possible the signal is clipping? I need a scope :/ They could be mixing errors that are being revealed by a more detailed playback, but if that’s the case less is more here.
This was due to bad RCA connections in a couple of older amps and acclimation to HD Audio's sharper high frequency. 80% bad connections though. The amps will be modified to take advantage of the balanced connections. The mains are already balanced and they are noticeably quieter than the other amplifiers.
