Originally Posted by m. zillch
Using speaker level inputs on a sub does not "rob available power" to one's main speakers in any significant or audible way, and is actually the preferred method according to some well respected, high end sub manufacturers.
I'm not saying I agree with them, mostly because of Audyssey's dedicated sub channel not getting engaged in this case, but I thought to point it out.
I'm confused. Are you responding to my post? The "waste pf electrical energy" I was referring to is the power being dissipated in the external amps he might be using unnecessarily. The AV7005 has a line-level (RCA) subwoofer output. If the subwoofer has a line-level input, using that line-level connection would be simpler, cooler, more cost-effective and more reliable (because fewer powered components would be involved). The amplifiers might be better used elsewhere. (And, as you say, using the line-level connection would provide better sound due to the use of Audyssey's dedicated subwoofer equalization.)
Of course, it's a different matter entirely if it's actually a passive subwoofer, which is why I asked for the exact model number in case there was a misunderstanding of some kind.
However, I was answering the OP's question as to the feature's availability as he simply wants to use the feature for "testing" purposes only.
By cleverly grouping this feature as if it were on par with the options of (normal) "Audyssey" and" Audyssey Flat", an average consumer might easily think this is an Audyssey sanctioned mode, like the other two indeed are, BUT IT IS NOT.
