AVS › AVS Forum › Video Components › Home Theater Computers › dts-hd pass through from dell studio 1557
post #1 of 13
I have a dell studio 1557 with windows 7 x64. It has a ati hd 4570 and I am trying to get DTS-HD to passthrough over HDMI to my HK avr254 receiver.....any ideas?
post #2 of 13
also...it only seems for some reason to support dolby digital......my receiver does dts-hd, and dolby-truehd
post #3 of 13
If I am reading this correctly, ATI Mobility Radeon HD4500 family does not support HD bitstreaming.
Integrated HD audio controller with up to 2 channel 48 kHz stereo or multi-channel (7.1) AC3 enabling a plug-and-play cable-less audio solution
You will get DD/DTS 5.1/6.1/7.1 via HDMI not Dolby TruHD or DTS-HD MA via HDMI.
Having HDMI does not automatically guarantee HD audio.
You need the Mobility HD4830/4860 family to get HD Audio
HDMI output support
Integrated HD audio controller with support for stereo and multi-channel (up to 7.1) audio formats, including AC-3, AAC, DTS, DTS-HD & Dolby True-HD, enabling a plug-and-play audio solution over HDMI5
post #4 of 13
HDMI output support
No, no, no!
HD 4000 series does not support HD audio passthrough. For that you need a card from the HD 5000 series.
HD 4000 however can do multi-channel LPCM over HDMI. Basically your software player decodes the HD audio track to PCM (kinda like unzipping) and sends it out over HDMI.
post #5 of 13
Not all 4000 series support 8 ch LPCM. Only the 48xx and beyond. The 43xx to 46xx (that OP has 45xx) only support stereo and AC3 (DD/DTS 5.1/7.1) over HDMI not even LPCM.
post #6 of 13
To be clear, this is only true of the "Mobility Radeon HD" line. All 4000 series cards from the desktop "Radeon HD" line support multichannel LPCM.
post #7 of 13
Well I was talking about mobility too.
But just so that we are on the same page.....
If you click specification on ANY of the the following DESKTOP cards you will not see DTS-MA or TrueHD listed till you reach 4850. There is no mention of them in 4200-4830 series even on the desktop cards.
http://www.amd.com/us/products/deskt...00-series.aspx
post #8 of 13
None of the 4000 series desktop cards will bitstream HD audio codecs (DTS-MA/TrueHD). They will all do multichannel (7.1) LPCM.
post #9 of 13
+1
At best, if you can decode TrueHD in software, you can send the LPCM to your receiver. For DTS-HD MA, you're stuck with the core DTS track, unless you have Arcsoft TMT (IIRC), which has its own proprietary decoder. In that case, it will also be the lossless LPCM.
Any ATi 4XXX card cannot send a bitstream of the lossless audio codecs.
post #10 of 13
does converting to lpcm degrade the quality? and since its a laptop, I can't change the video card...is there anything else i can do?
post #11 of 13
Depends on the software used. Commercial players will downconvert to 48/16 (if the track is a higher quality). Some can hear it the difference and some can't so this is a debatable "downgrade" in the sound. FFDShow (used in the directshow player of your choice) will fully decode all formats except for DTS-HD with no quality loss. Using eac3to to decode the audio to LPCM (for ripping to MKV and the like) will work on all formats and the output from any player will be without any downgrade.
post #12 of 13
Where it's a laptop most of the standard thoughts about the 4xxx line do not apply. Your card has the same audio support as a 3xxx desktop card, which means you can bitstream legacy DD and DTS but not TrueHD or DTSHD.
You can output stereo LCPM at highres but not multichannel. For Blurays this means you can playback the core legacy track in surround but not the HD track.
There is also not much you can do to upgrade the laptop to do more. Sorry to be the bearer of bad news.
post #13 of 13
Ah yes, Thrillho is correct. I keep forgetting that we are discussing a Mobile 4xxx chip.
