I would be so happy if Panny made a TC-P58G25, geez!!! but they don't, so I am stuck picking one of these sets...
P54G25
Pros: Best AR filter (by far), 2nd best PQ
Con: Very small TV for distance
60PK550
Pros: Best PQ, Largest
Con: No AR filter at all
58S2
Pros: 2nd best Size, 2nd best AR filter
Con: PQ
Ok so this is going into the basement with windows on the two sides but from what i can see sunlight does not come directly into the room very often. There are two overhead lights that will sit directly behind the set, on center, one about 10ft away and another about 20ft. I will be sitting 12-14 feet away from the TV.
I am not going to have the tv professionally calibrated, but I would be willing to change some settings based on online resource.
Help me pick which one YOU would buy, and why.
P54G25
60PK550
58S2
Con: PQ
Get the 58vt25
. To me the PK550 has no more reflection overall than the CRT tube televisions i've owned in the past.
