I have a ton of CAT5e run between my fireplace and my AV stack in a downstairs closet. For setup and testing I terminated two pairs and have 2 sets of cat5e-HDMI baluns at this location (even though eventually only one will be necessary). Both were working nicely.
Then on an unrelated matter I flooded a neighboring bedroom with my fish tank. A bit of wetness got into the closet... no worries, though, as the gear was elevated and safe. I slid it a few feet out and into the room so I could get some air circulation in there, and then:
a) one of the cable boxes stopped working. It's just plain broken. Won't send a signal via any output, can't get the right time from the cable input anymore, etc. Worthless.
b) both sets of Cat5e pairs stopped working.
On one, the light on the receiving end doesn't light up, which indicates bad cable. On the other, the light is on but I still don't get a signal.
Is this stuff extra finicky? Obviously I have to test each cable individually, and I will... but could they have gotten screwed up simply by being twisted funny around a corner as I moved the stack?
I don't have a huge amount of trust in the baluns either, but they seem to be doing what they're supposed to. I need to test the cable first.
Just sort of curious about what kind of expectations to have. I can pull new Cat5e or Cat6 through, but only if I replace what's there (tight hole on this end that I can't expand). So I'm clear - is there any way that a terminated Cat5e cable can carry ethernet signal from my cable modem to my laptop (my easiest means of testing each one individually) but NOT support the HDMI bandwidth anymore?
Although I completely agree, I'd never recommend 5e over 6 in a job these days (or for the past, say, 3 years).
