Double-check the cables/connections. Something has changed.
I'm sorry I can't help more, but I've never used this feature. So my suggestions are all basic stuff.
Jeff
). I wonder if it would be possible to hang something soft and absorbent on at least one of the walls, or to add a large rug in front of the couch. Also, that big reflective surface that is the coffee table is likely to cause some reflections that may muddy the sound from your centre speaker. Talking of the centre speaker, it's a good idea, if you can, to pull it clear of any shelf so that the front edge of the speaker is clear of the shelf itself, and to angle the speaker up slightly to face you when you are in the listening position.
) and once the work was done, there would be no evidence that it had ever been done so for just a little disruption now you would be able to perfect your sound for ever. It would definitely be worth it.
